Devices Network
Further Configuration
MADRIX allows to activate or deactivate drivers or network communication protocols for various products.
Devices Network
Activate the required drivers.
[When activated, MADRIX automatically searches for supported devices at startup.]
You can enable 6 particular network drivers here:
Philips Color Kinetics - KiNET
inoage - MADRIX [for MADRIX LUNA, MADRIX NEBULA, MADRIX PLEXUS, and MADRIX STELLA]
MA Lighting - MA-Net
ROBE StageQube324 / Insta instalight 2022
ESTA - Streaming ACN
Capture - CITP
Philips - Hue
When activating a driver, please always make sure that you have selected the correct network card.
Further configuration is needed:
Devices Network only activates the required drivers and often the corresponding network card.
Make sure to configure your hardware interfaces also according to your requirements.
Learn more
»Philips Color Kinetics [KiNET]
»MADRIX LUNA
»MADRIX NEBULA
»MADRIX PLEXUS
»MADRIX STELLA
»MA-Net
»ROBE StageQube 324 [ROBE Protocol]
»Insta instalight 2022 - LED-Panel RGB 324 [Insta Protocol]
»ESTA - Streaming ACN [sACN / E1.31]
»CITP
»Philips Hue
Only activate the drivers you require. In this way, you can speed up the loading/starting time of MADRIX.
All options of Devices Network will be saved locally on your computer. The settings described in this topic will not be saved in your MADRIX Setup file.
MADRIX 3.6h
