User Interface
Cue List
General
Thumbnails
Touch
Go to Preferences > Options... > User Interface
[Keyboard shortcut: Ctrl+Alt+O > User Interface]
User Interface
Set up user interface options as explained below.
Cue List
You can choose how MADRIX manages the user interface when playing back the Cue List.
Learn more »Cue List
General
Keep Aspect Ratio When Maximized - Keeps the original aspect ratio of the user interface if you maximize the window of MADRIX. That means when maximized, the window will be scaled according to the original dimensions.
Aspect Ratio On
Aspect Ratio Off
Aspect Ratio On
Aspect Ration Off
Show Menu In Full Screen Mode - Allows you to display or hide the menu bar in full screen mode. Learn more »Full Screen Mode
Thumbnails
MADRIX provides thumbnails to preview Storage Places and their included visuals on the main user interface »Storage Places [256 x 256] as well as on the touchscreen interface »Touch Screen.
Since these buttons are usually square-like, it depends on the aspect ratio of your virtual matrix how much button space is used. When using a very rectangular matrix, the thumbnail is often shown very wide, but not very high. You can change that and activate the option to stretch the thumbnails to the full button size.
Stretch
For example:
Stretch Activated
Stretch Deactivated
Aspect Ration Off
Please note: According to the way thumbnails are generated, your thumbnails need to be up to date before the stretch option is applied. They will be updated when switching to another Storage Place to always show the last visual state.
Touch
MADRIX features a special Touch Screen window to control the software via a touch screen panel. You can set up certain options for this extra panel.
Learn more »Touch Screen
Touch Screen Window
All options of User Interface will be saved locally on your computer. The settings described in this topic will not be saved in your MADRIX Setup file.
MADRIX 3.6i
