Devices USB
Devices USB
Supported MADRIX Devices
Supported Third-Party Devices
Further Configuration
Important Information
MADRIX allows to activate or deactivate drivers for various hardware interfaces, such as MADRIX NEO and others.
Go to Preferences > Options... > Devices USB
Devices USB
Activate the required drivers for your hardware interfaces.
[When activated, MADRIX automatically searches for supported devices at startup.]
»MADRIX USBone
»MADRIX NEO
»MADRIX PLEXUS
»MADRIX LUNA
»MADRIX NEBULA
»MADRIX STELLA
»MADRIX I/O
»MADRIX USB SMPTE
MADRIX also supports a number of 3rd-party interfaces.
Learn more »Supported DMX512 And Art-Net Interfaces
Learn more »GamePort
Further configuration is needed:
Devices USB only activates the required drivers.
Make sure to enable and configure your hardware interfaces also according to your requirements.
Learn more »DMX512 [DMX-OUT]
If you only activate drivers for devices which you are effectively going to use,
 - you can speed up the loading/starting time of MADRIX.
 - you can avoid problems with other interfaces.
 - you can avoid problems with other software running on your computer which also controls such DMX interfaces.
All options of Devices USB will be saved locally on your computer. The settings described in this topic will not be saved in your MADRIX Setup file.
MADRIX 3.6i
