ROBE StageQube 324 [ROBE Protocol]
Note
Gigabit Network Components
Step-By-Step Configuration
Additional Functionality
Further Configuration
Robe StageQube 325
MADRIX natively supports the ROBE Protocol for ROBE StageQube 324™ LED panels.
To use ROBE StageQube 324, you need to have a separate DHCP server.
This can be a software or hardware DHCP server, which handles the IP addresses of the ROBE LED panels and the MADRIX computer.
It is recommended that the DHCP server binds MAC addresses to IP addresses.
ROBE Configuration Illustration
ROBE Set-up Illustration
Note
There are several steps required to set up ROBE products in MADRIX. This chapter is only part of the process. You need to set up other configurations as well [such as virtual LED matrix, DMX Devices, MADRIX Effects, Audio, etc.].
It is recommended to only use 1000 MBit/s network components. That means 1000 MBit/s network cards in your computer, 1000 MBit/s switches and a DHCP server with support of 10/100/1000 MBit/s if your setup looks like the configuration shown above.
1] Configure network settings in Windows.
2] Enable ROBE Drivers in MADRIX.
3] Activate devices.
4] Configure devices.
5] Set up the correct DMX universe.
6] Set up the Frame Time.
1] Windows Network Settings
The protocol from ROBE is a network-based protocol. MADRIX will use the network card of your computer to send data.
You must use these IP address and Subnet mask settings.
The IP addresses of your computer and your ROBE devices need to be different.
Set up an individual IP address in the following IP address range:
- 10.0.0.1 ... 10.255.255.254
- 255.0.0.0
Restart MADRIX, if you have changed the network settings in Windows while MADRIX was running.
2] Enabling Drivers In MADRIX
Activate Enable Network Driver
Choose the correct network/network card from the drop-down list.
- Always make sure that you have selected the correct network. Otherwise, the network device might still be found. But no data can be sent.
Devices (Network)
Time To Detect Devices (s) - Defines how long MADRIX searches the network for devices during startup. Type in a value in seconds.
- We recommend to utilize at least a value of 10 to allow for a sufficient search. Higher values are recommended for larger installations.
Adjust White Balance - Activate and MADRIX automatically performs this automatic calibration on startup. Connected panels will adjust their white value to the maximum value possible in the installation to ensure a similar color temperature. If the adjustment takes longer than 100 seconds, MADRIX will send data nevertheless. Uncheck this option if you want to deactivate it.
3] Activating Device
[Keyboard shortcut: F4]
MADRIX automatically adds network devices it has found during startup to the list.
Click if the devices have not been found.
- MADRIX disconnects all DMX512, Art-Net, and other devices and starts to search for new or newly connected devices.
Select your devices in the list.
Activate Enable
Activate Output
Click Apply
DMX Devices
4] Configuration Of Devices
Select a device in the list and click
A new window will open.
Device Configuration
Set up the following settings for your device [for the Left Panel Half as well as the Right Panel Half]:
Brightness - Defines the maximum output intensity.
Contrast - Defines the color contrast.
Luminesce Time - Defines the luminesce tine of the panel.
Frequency - Defines the frequency of the panel.
Red - Defines the maximum red color intensity.
Green - Defines the maximum green color intensity.
Blue - Defines the maximum blue color intensity.
Enable Live Preview - Activates the reception of parameters live from the device.
Defaults - Restores the default settings.
5] DMX Universe
Make sure that your device is still selected.
Set up Universe
- Enter the specific DMX universe number
Make sure the correct universe is assigned according to your requirements.
Learn more »Glossary
Click Apply
6] Frame Time
Set up Frame Time (ms)
Click Apply
Rescan For Devices
Highlight Device Button
Rescan For Devices - MADRIX disconnects all DMX512, Art-Net, and other network devices and starts a new search for devices.
Highlight Mode
Highlight - Activates the highlight mode for the selected interface and universe under Preferences > Device Manager... > DMX Devices. Select one or more interfaces and click the button. The corresponding fixtures at the selected interfaces will flash for a better identification or tests. This makes it easier to see them on stage. It considerably speeds up the procedure of programming or testing the selected DMX512/Art-Net interfaces.
DMX Watcher
DMX Watcher
Learn more »Tools
Resizing The Window
Keep in mind that network devices, if activated, cause network traffic!
When using a network-based output protocol and when the Startup option Start MADRIX After Booting Windows is used, it is highly recommended to also activate the Startup option Start With Timeout (s) with a value of 30 or higher.
It is not recommended to use communication over the Insta/ROBE protocols and KiNET in the same network!
It is not recommended to operate the ROBE protocol and access to the World Wide Web/Internet in the same network! It is recommended to run it in a separate network without internet access.
MADRIX 3.6i
