MADRIX NEO
MADRIX 3.X Minimum System Requirements
MADRIX 3.X Supported Operating Systems
Loading The Drivers
Using DMX Output or DMX Input
Further Configuration
Interruption-Free Operation
Using A MADRIX KEY Instead Of A MADRIX Interface
Important Information
MADRIX NEO is a USB 2.0 DMX512 interface. It can be used for input [DMX-IN] or output [DMX-OUT].
The MADRIX software license for 512 DMX channels is already included.
Important Note
Make sure to read the provided MADRIX NEO Quick Start Guide first!
»help.madrix.com
2.0 GHz dual-core CPU
OpenGL 2.0 graphics card [NVIDIA recommended]
2 GB RAM
1 GB free harddisk space
1280 x 768 screen resolution
Sound card
USB 2.0
Microsoft Windows 7
Microsoft Windows 8
Microsoft Windows 8.1
Microsoft Windows 10
Compatible with 32 bit and 64 bit
Loading The Drivers
Go to Preferences > Options... > Devices USB
Activate MADRIX USBone / MADRIX NEO
Click Apply to confirm.
Click OK to close the window.
Using DMX Output Or DMX Input
The NEO allows you to send or receive data via MADRIX using 512 DMX channels.
The MADRIX NEO features a 5-pin, female XLR connector.
If you want to use DMX-IN, please use a 5-pin XLR male to 5-pin XLR male gender changer.
Learn more »DMX512 [DMX-OUT]
Learn more »DMX-IN / Art-Net Remote / sACN Input
To ensure interruption-free operation of the software and devices, please make sure to check the power-saving settings of Windows.
Learn more »PC Power Management
Using A MADRIX KEY Besides A MADRIX Interface
When using a MADRIX KEY in addition to a MADRIX hardware interface, please make sure to install the required software components during the installation process [MADRIX KEY Driver].
Learn more »Installation Process
MADRIX NEO already includes the MADRIX software license for 512 DMX channels. The data output [the license] is automatically activated when you connect the PLEXUS to a computer that has the MADRIX software installed and running and the USB drivers enabled in the software.
The MADRIX KEY is not necessary for the MADRIX PLEXUS.
The MADRIX KEY is not necessary for the MADRIX NEO.
Up to 60 NEOs can be connected to a USB host controller without having any frame rate problems. Please connect every NEO to an active USB 2.0 port or use a USB 2.0 hub with a power supply.
