Supported DMX512 Interfaces
This list may not be complete and support may vary depending on the product.
MADRIX
| ▪ | MADRIX USBone / USB ONE - USB 2.0 interface, 512x DMX-OUT or 512x DMX-IN |
| ▪ | MADRIX NEO - USB 2.0 interface, 512x DMX-OUT or 512x DMX-IN |
| ▪ | MADRIX PLEXUS - USB 2.0 interface, 1024x DMX-OUT, or 1024x DMX-IN, or 512x DMX-IN and 512x DMX-OUT, live or stand-alone |
| ▪ | MADRIX LUNA 4 - USB 2.0 interfaces, 2048x DMX-OUT, 512x DMX-IN |
| ▪ | MADRIX LUNA 8 - USB 2.0 interfaces, 4096x DMX-OUT, 512x DMX-IN |
| ▪ | MADRIX LUNA 16 - USB 2.0 interfaces, 8192x DMX-OUT, 512x DMX-IN |
| ▪ | MADRIX NEBULA - USB 2.0 interfaces, 4096x OUT |
| ▪ | MADRIX STELLA - USB 2.0 interface, 1024x DMX-OUT, or 1024x DMX-IN, or 512x DMX-IN and 512x DMX-OUT |
Daslight
| ▪ | DVC2 512 - USB 2.0 interface, 512x DMX-OUT and 512x DMX-IN |
| ▪ | DVC2 ECO 512 - USB 2.0 interface, 512x DMX-OUT and 512x DMX-IN |
| ▪ | DVC2 Gold - USB 2.0 interface, 1024x DMX-OUT |
| ▪ | DVS 3D - USB 2.0 interface, 512x DMX-IN |
Elation Professional
| ▪ | Compu 1024EC - USB 2.0 interface, 512x DMX-OUT or 512x DMX-IN [via DasHard2006] |
| ▪ | Compu 2048FC - USB 2.0 interface, 512x DMX-OUT or 512x DMX-IN [via DasHard2006] |
| ▪ | Compu 2048FC+ - USB 2.0 interface, 512x DMX-OUT or 512x DMX-IN [via DasHard2006] |
FTDI
| ▪ | FTDI drivers can be used for devices that are commonly using a chip by FTDI [Future Technology Devices International Limited]. |
| ▪ | Support and functionality may vary depending on the product and cannot be guaranteed. |
| ▪ | In general, input is not supported [DMX-IN]. Only output is available in MADRIX [DMX-OUT]. |
| ▪ | The driver could be used for the following devices [list may not be complete]: |
| ▪ | DMXking ultraDMX RDM Pro - USB 2.0 interface, 512x DMX-OUT |
| ▪ | DMXking ultraDMX Pro - USB 2.0 interface, 512x DMX-OUT
| ▪ | ENTTEC Open DMX USB Interface - USB 2.0 interface, 512x DMX-OUT |
| ▪ | ENTTEC DMX USB Pro - USB 2.0 interface, 512x DMX-OUT |
| ▪ | EUROLITE USB-DMX512 Interface - USB 2.0 interface, 512x DMX-OUT
| ▪ | STRATUS LIGHT Interface converter USB-DMX 512 / Light Open DMX - USB 2.0 interface, 512x DMX-OUT
| ▪ | USBDMX.com Interface - USB 2.0 interface, 512x DMX-OUT
[Requires: FTDI driver version 1.6 or higher; FTDI drivers included in MADRIX are recommended; the original USBDMX.com driver is not recommended] |
Nicolaudie - Sunlite
| ▪ | SLESA - USB interface, 512x DMX-OUT |
| ▪ | SLESA-IP1 - Ethernet interface, 512x DMX-OUT [via Art-Net mode] |
| ▪ | SLMEV - USB interface, 512x DMX-IN |
peperoni-light
| ▪ | Rodin1 - USB 2.0 interface, 512x DMX-IN or 512x DMX-OUT |
| ▪ | Rodin2 - USB 2.0 interface, 512x DMX-OUT or 512x DMX-IN |
| ▪ | RodinT - USB 2.0 interface, 512x DMX-OUT or 512x DMX-IN |
Soundlight
| ▪ | SLESA-IP - Ethernet interface, 512x DMX-OUT [via Art-Net mode] |
| ▪ | USBDMX-ONE - USB 2.0 interface, 512x DMX-IN or 512x DMX-OUT |
| ▪ | USBDMX-TWO - USB 2.0 interface, 1024x DMX-OUT, or 1024x DMX-IN, or 512x DMX-IN and 512x DMX-OUT |
How To Test DMX512 Interfaces
Please follow these steps to see if your interface works correctly with MADRIX:
1] Connect the interface you want to test with your computer.
2] Make sure that Windows recognizes the interface and that all necessary drivers have been installed correctly.
3] Start MADRIX.
4] In MADRIX, activate the correct drivers for your interface. Learn more »Devices USB
5] Check if the interface is recognized by MADRIX and assign the correct output settings for your device. Learn more »DMX512 [DMX-OUT]
Supported Art-Net Interfaces
MADRIX
Third Parties
All interfaces that are fully compatible with Art-Net [Art-Net I, Art-Net II, Art-Net III] will work with MADRIX. Support is defined by compatibility with Art-Net and not limited to specific brands.
How To Test Art-Net Interfaces
1] Set up the correct network settings in Windows.
2] Connect the interface you want to test with your computer via network.
3] Start MADRIX.
4] Activate Art-Net in MADRIX and add your devices.
Learn more »Art-Net [DMX Over Ethernet]
