SCE Morse Code
SCE Morse Code
SCE Morse Code displays words and characters in visual signals with the help of the morse-code alphabet.
▪BPM - Defines the speed. The default value is 120. Valid values range from 0 to 9999.
- Every signal is displayed a certain number of beats.
- Short: 1 Beat / Long: 2 Beats / Pause Between Characters: 1 Beat / Pause Between Words: 3 Beats
- 1 Beat At 60 BPM = 1 Second / 1 Beat At 120 BPM = 1/2 Second / Etc.
- Learn more »Using BPM Control
▪Message - Enter any text that should be displayed as morse code. The default value is MADRIX.
▪Fade In - Defines if the color is immediately displayed or faded in [in %]. The default value is 50. Valid values range from 0 to 100.
▪Fade Out - Defines if the color is immediately cleared or faded out [in %]. The default value is 50. Valid values range from 0 to 100.
Color-Change Indicator - Is only available when having set up multiple colors in the Color Table.
Defines the indicator after which the color is changed when having set up multiple colors in the Color Table. Choose from None, Signal [a character often consist of several signals], Character [individual characters make up entire words or are single symbols], Word [a message may consist of several words], Message [after the text has been fully displayed once]. The default value is Message.
Morse-Code Alphabet - Defines in which morse-code alphabet the message should be displayed. Choose from: Arabic, Chinese, Cyrillic, Greek, Hebrew, Latin, Persian. The default value is Latin.
Loop - Repeats the message endlessly, i.e. the effect is restarted once the end of the message has been reached. It is activated by default.
Autostart - If activated, the effect will automatically start when the corresponding Storage Place is selected. It is activated by default.
Start - Force-starts the effect to start again from the beginning.
MADRIX 5.8.
