Hardware Features
You Are Here:  General >
Hardware Features
▪Make sure to read the provided MADRIX AURA Technical Manual & Quick Start Guide first!
Find it in your product box or download it from »help.madrix.com
Frame Rates
In general, please note the following:
44 FPS is the maximum refresh rate for full frames of 512 DMX channels according to ANSI E1.11 – 2024 (USITT DMX512-A)!
A higher frame rate is outside of the official DMX specifications and requires compatibility of your devices.
MADRIX AURA can:
▪Play back and output up to 50 FPS for full-frame scenes with 512 channels per DMX frame [depending on which frame rate was received during recording].
▪Play back and output higher frame rates if DMX frames include less than 512 channels [up to 100 FPS max.].
Using A 3rd-Party Controller
MADRIX AURA is a standard network node for Art-Net or Streaming ACN. You can use the device with any compatible application, console, or controller.
Daisy-Chain Support
▪MADRIX AURA features 2 separate Ethernet network ports. Either one is fully functionally for IN and OUT.
▪They can also be used for the data connection in daisy-chain manner without using a separate network switch or router.
▪We recommend to connect a maximum of
- 160x MADRIX AURA 2,
- 40x MADRIX AURA 8,
- 26x MADRIX 12, or
- 10x MADRIX AURA 32
after one another in a row without any additional devices connected to this network line.
▪You can also use MADRIX AURA 2, 8, 12, or 32 together in any combination.
On-Device Buttons
Buttons
Press
Description
Short
Plays Current Cue
Please note:
▪Make sure that MADRIX AURA is the only sender in the network when playing back scenes.
[You will run into issues if the original sender from which the device recorded its data from is still sending to the same universes.]
When Paused
Plays Current [Last Played] Cue
When Stopped
Short
Pauses Playback
[The last frame will still be sent.]
Short
Starts Recording
Please note:
▪Make sure to send control data to the device before you start a recording process [Art-Net or Streaming ACN]!
▪Based on the FAT32 file system, files on the SD card can only have a maximum file size of 4 GB. Should the current recording process create files with such a file size, MADRIX AURA will automatically create new files and continue recording, and add a second index number to the file name in addition to the original index.
▪Recorded data that is saved on the SD card will be encrypted first.
When Stopped
Short
Stops Playback Or Recording
Short
Skips To Next Cue
Short
Returns To Previous Cue
Short
Sends Art-Net PollReply
During Startup
Resets To Manufacturer Default Settings
[Incl. Default IP Address]
Make sure to disconnect and re-connect Power and/or USB first.
All status LEDs blink 3x for confirmation.
Short
Increases Intensity By 10 %
Up To 100 %
[MADRIX logo blinks if maximum has been reached.]
Medium
Increases Intensity Slowly
Long
Increases Intensity Quickly
Short
Decreases Intensity By 10 %
Down To 0 %
[MADRIX logo blinks if minimum has been reached.]
Medium
Decreases Intensity Slowly
Long
Decreases Intensity Quickly
For 3 Seconds
Resets Intensity To 100 %
Short
Increases Speed By 10 %
Up To 1000 %
Medium
Increases Speed Slowly
Long
Increases Speed Quickly
Short
Decreases Speed By 10 %
Down To 1 %
Medium
Decreases Speed Slowly
Long
Decreases Speed Quickly
For 3 Seconds
Resets Speed To 100 %
Special Commands
▪Technical support might ask you to perform the following commands.
For 2 Seconds
During Startup
Load Bootloader Only
Disconnect and re-connect Power and/or USB first.
If successful, the status LED Power is blinking green.
Automatic HTP Merging
▪MADRIX AURA features automatic HTP merging from 2 Ethernet sources.
▪Data from both sources will be merged together and received as 1 signal. The HTP principle is used. This happens across each single Universe.
▪HTP - Is the acronym for Highest Takes Precedence. Data from both sources will be compared for each individual channel. The higher value wins per channel.
▪Sources can be:
- 1x Art-Net + 1x Art-Net
- 1x Art-Net + 1x sACN
- 1x sACN + 1x sACN
LED Status Codes
The following tables describe the LED status codes of the device.
STATUS
STATUS LED POWER
Off
Power not connected. > The device has no power.
Green on
Connected to power. > The power is on.
Green blinking
Bootloader activated. > Reset device / upload firmware.
STATUS
STATUS LED USB
Off
USB not connected.
Green on
USB connection established.
STATUS
STATUS LED SD CARD
Off
No SD card inserted.
Green on
SD card inserted.
STATUS
STATUS LED ETHERNET
Off
Ethernet not connected.
Green on
Ethernet connection established.
STATUS
STATUS LEDS ETHERNET PORTS
Off
No network connected.
Green on
1000 MBit/s connected.
Green blinking
Sending or receiving data. > The Ethernet port works.
Orange on
100 MBit/s connected.
Orange blinking
Green + Orange on
10 MBit/s connected.
Green + Orange blinking
STATUS
STATUS LED OPERATION
Off
No playback or recording active / playback stopped.
Green on
Playback paused.
Green blinking
Playback from SD card.
Red blinking
Recording currently active.
STATUS
STATUS LED ETHERNET
On
Normal status.
Fading
Changing intensity or speed.
Blinking
Min./max. intensity/speed reached or Highlight Device active.
Recording
Note: MADRIX AURA will be recording blank scenes [DMX value = 0 = black] even if no data is received.
This behavior is necessary to ensure synchronicity between devices regarding Master-Slave Synchronization. If you record 5 scenes with multiple devices, but one unit only recorded 3 scenes because no data has reached it during two scenes, the cue lists of the devices would not match and the synchronization would fail.
This is true even if you are not using Master-Slave Synchronization. You might want to record the same scenes to several devices and use them in different projects. This behavior will ensure that they all create the same scenes and cue lists; independently of the data they received.
LED Status Indicators [ArtAddress]
MADRIX AURA supports the ArtAddress feature of Art-Net. The device will operate as desired if the correct commands are sent to it.
Mute Status Indicators
Switches off and disables all built-in status indicators of a device over Art-Net [ArtAddress > AcLedMute].
Operate Status Indicators Normally
Allows the built-in status indicators of a device to operate normally again, after having them switched off [ArtAddress > AcLedNormal].
Highlight Device
Activates the highlight mode [ArtAddress > AcLedLocate]. The corresponding status indicators of the selected interfaces will flash for a better identification or tests. This makes it easier to see them on site/stage. It considerably speeds up the procedure of programming or testing the selected interfaces.
See also »Highlight Device
Reset To Factory Default Settings
Reset Via On-Device Buttons
▪Press the following 3 buttons during startup:
▪All status LEDs blink 3x for confirmation.
Reset Via Ethernet [Web Configuration]
▪1] Connect MADRIX AURA to power.
[Please see safety instructions in the MADRIX AURA Technical Manual & Quick Start Guide]
▪2] Connect MADRIX AURA and your computer to the same Ethernet network.
▪3] Assign correct network settings for your computer in the operating system.
[Recommended default settings: IP address 10.0.0.1 / Subnet mask 255.0.0.0]
▪4] Open your web browser and enter the IP address of MADRIX AURA. The built-in web configuration tool will be launched.
[You can find the default IP address on the side of the device.]
▪5] Go to Settings > Special Commands > Execute Function : > Choose Reset To Factory Default Settings and confirm with Set
Learn more »Settings - Device Settings
Reset Via USB Or Ethernet [MADRIX HARDWARE MANAGER]
▪2] Connect MADRIX AURA to your computer via USB or Ethernet.
[You can use the provided USB cable or a separate network cable is required.]
▪3] Start the separate MADRIX HARDWARE MANAGER
[In Windows 10, go to Start > MADRIX HARDWARE MANAGER > MADRIX HARDWARE MANAGER
▪4] Select a device/devices in the list.
▪5] Right Mouse Click > Restore Factory Default Settings
[Wait for the reset process to end [usually it takes only seconds.]
Learn more »Using MADRIX HARDWARE MANAGER [USB / Ethernet]
SD Cards
MADRIX AURA uses a memory card to run automatic light shows without the need for a computer.
▪The integrated SD-card slot is located at the top of the device.
▪It supports SD, SDHC, or SDXC cards (tested up to 64 GB).
Attention:
▪SD cards for usage with MADRIX AURA need to be formatted with FAT32 File System and 64 kilobytes Allocation Unit Size. A capacity of > 4 GB is recommended.
You can use the special function provided on the device's website. Learn more »Special Commands
▪For the best performance and operation, always use a freshly formatted SD card.
Recording Length
▪Recording length AURA 2 – 64 GB: ~526 h (33 FPS) / ~347 h (50 FPS)
▪Recording length AURA 8 – 64 GB: ~131 h (33 FPS) / ~86 h (50 FPS)
▪Recording length AURA 12 – 64 GB: ~85 h (33 FPS) / ~57 h (50 FPS)
▪Recording length AURA 32 – 64 GB: ~32 h (33 FPS) / ~21 h (50 FPS)
MADRIX AURA User Manual 4.01.
