MADRIX USB ONE
MADRIX 5 Software License
Loading The Drivers
Using DMX Output Or DMX Input
Further Configuration
Interruption-Free Operation
MADRIX USB ONE is a USB 2.0 DMX512 interface. It can be used for input [DMX-IN] or output [DMX-OUT].
The MADRIX USB ONE allows you to control 512 DMX channels in combination with the MADRIX 5 Software.
The MADRIX 5 Software license is not included and sold separately. A MADRIX 5 KEY is necessary if you want to use DMX output [DMX-OUT].
No separate license is required for DMX input [DMX-IN].
Loading The Drivers
Go to the menu Preferences > Options... > Devices USB
Activate MADRIX USB ONE / MADRIX NEO
[The option is activated by default.]
Click Apply to confirm.
Click OK to close the window.
The MADRIX USB ONE allows you to send [DMX-OUT] or receive [DMX-IN] data via MADRIX 5 using 512 DMX channels.
The MADRIX USB ONE features a 5-pin, female XLR connector.
If you want to use DMX-IN, please use a 5-pin XLR male to 5-pin XLR male gender changer.
Learn more »DMX512 [DMX-OUT]
Learn more »DMX-IN / Art-Net Remote / sACN Input
Make sure to save your MADRIX 5 Setup after the configuration process.
To ensure interruption-free operation of the software and devices, please make sure to check the power-saving settings of Windows.
Learn more »PC Power Management
