SCE Level Color Simulator
SCE Level Color Simulator simulates audio input and displays the loudness of the input with the help of color. The more input, the brighter the effect.
Colors - Opens the Color Gradient to specify the colors. The default color is White, Black.
Fade Out / In - Defines how fast MADRIX 5 displays color. You can specify the fade-in speed as well as the fade-out speed. The default values are 120 and 120. Valid values range from 1 to 3000.
Mode - Allows you to choose the mode [Mono, Stereo Linear, Stereo Radial]. This heavily influences the visual outcome of the effect.
Direction - Allows you to choose the direction. This includes all directions for 2D and 3D mode. The default setting is Right. Learn more »Using Directions
