SCE Fluid
SCE Fluid
SCE Fluid simulates gas or liquids.
Effect Options
Learn more »Effect Options
Colors - Opens the Color Table or Color Gradient depending on the Color Mode. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta.
BPM - Defines the speed. The default value is 3000. Valid values range from 0 to 9999.
Radius - Defines the size of impulses [in %]. The default value is 10. Valid values range from 0 to 100.
Vorticity - Defines how much impulses can swirl in the gas [in %]. The default value is 12. Valid values range from 0 to 100.
Duration - Defines how long impulses can move through the gas [in %]. The default value is 64. Valid values range from 0 to 100.
Density - Defines the thickness of the gas [in %]. The default value is 10. Valid values range from 0 to 100.
Velocity - Defines how fast impulses can move through the gas [in %]. The default value is 10. Valid values range from 0 to 100.
Fade - Defines how quickly impulses evaporate [in %]. The default value is 5. Valid values range from 0 to 100.
Deceleration - Slows down the movement of impulses [in %]. The default value is 0. Valid values range from 0 to 100.
Direction - Allows you to choose the direction of the movement. The default setting is Up. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default setting is Up. Learn more »Using Directions
Color Mode - Allows you to choose the color mode [Color Table or Color Gradient]. The default setting is Color Table.
MADRIX 5.7.
