SCE Fill Solid |
SCE Fill Solid constantly fills the matrix with a new color.
▪This MADRIX Effects supports Effect Options for advanced workflows. Learn more »Effect Options
This MADRIX Effect uses the following, individual controls: ▪Colors - Opens the Color Table to specify the colors. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta. ▪Fill Time - Defines the time how long it takes to fill the complete LED matrix with shapes [in s]. The default value is 5. Valid values range from 0.01 to 3600. ▪Duration - Defines the time the complete matrix is shown in solid color until the next round of objects begins to fill the matrix [in s]. The default value is 1. Valid values range from 0 to 3600. ▪Step Width - Defines the number of pixels the effect should scroll in the direction per frame [in %]. The default value is 0.01. Valid values range from 0.01 to 100. ▪Color Width - Is only available for Color Mix Mode [»[Global] Colors And Intensity]. Defines the width of a single color [in %]. The default value is 10. Valid values range from 0.01 to 100. ▪Cross Width - Is only available for Cross Mode [»Using Directions]. Defines the size of crossing colors [in %]. The default value is 50. Valid values range from 0.01 to 100.
MADRIX 5.6. |
