SCE Color Change
SCE Color Change
SCE Color Change automatically changes colors.
This MADRIX Effect creates a completely seamless loop.
Effect Options
Learn more »Effect Options
BPM - Defines the speed. You can either use BPM or Time. The default value is 60. Valid values range from 0 to 9999.
Time - Defines the time interval a color is displayed [in s]. You can either use BPM or Time Slot. The default value is 1. Valid values range from 0.01 to 9999.
MADRIX 5.7.
