SCE Clouds |
SCE Clouds creates random, organic visuals that are reminiscent of clouds.
This MADRIX Effect uses the following, individual controls: ▪Colors - Opens the Color Gradient to specify the colors. The default color is White, Black. ▪BPM - Defines the speed [when using a direction/movement]. The default value is 1500. Valid values range from 0 to 9999. ▪Frequency - Defines the rate at which new, organic visuals are created [in Hz]. The default value is 10. Valid values range from 0 to 50. ▪Stretch - Defines the stretch or compression factor at which the visuals are displayed [X, Y, Z]. The default values are 1, 1, 1. Valid values range from 0.01 to 1000. ▪Contrast - Defines the visual differentiation of colors and shapes [in %]. The default value is 50. Valid values range from 1 to 1000. ▪Detail - Defines the sharpness [in %]. The higher the Detail, the more computer performance is required. The default value is 2. Valid values range from 1 to 10. ▪Distinction - Defines the cohesiveness of the effect [in %]. The default value is 50. Valid values range from 1 to 100.
MADRIX 5.6. |
