S2L Level Meter |
S2L Level Meter displays the audio input level. By default, the left audio channel and the right audio channel are shown.
This MADRIX 5 Effect uses the following, individual controls: ▪Color - Opens the Color Gradient to specify the colors. The default color is White, Black. ▪Drop - Defines how quickly the effect is shown. The default value is 50. Valid values range from 1 to 100. ▪Fade - Defines how fast MADRIX 5 displays the effect. The default value is 3000. Valid values range from 1 to 3000. ▪Width 1 - Defines the first size of spectrum bars depending on the direction [in % of the Matrix Size]. The default value is 50. Valid values range from 0.01 to 100. ▪Pitch 1 - Defines the first distance between objects depending on the direction [in % of the Matrix Size]. The default value is 50. Valid values range from 0.01 to 100. ▪Width 2 - Defines the second size of spectrum bars depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100. ▪Pitch 2 - Defines the first distance between objects depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100.
| MADRIX 5.7. |
