M2L Tubes
You Are Here:  MADRIX Effects > [M2L] Music2Light Effects >
M2L Tubes
M2L Tubes displays the music in form of tubes.
Effect Options
Learn more »Effect Options
Fade - Defines how fast MADRIX 5 displays the effect [in %]. The default value is 60. Valid values range from 1 to 3000.
Size 1 - Defines the first size of tubes depending on the direction [in %]. The default value is 10. Valid values range from 0.01 to 100.
Pitch 1 - Defines the first distance between tubes depending on the direction [in %]. The default value is 10. Valid values range from 0.01 to 100.
Size 2 - Defines the second size of tubes depending on the direction [in %]. The default value is 100. Valid values range from 0.01 to 100.
Pitch 2 - Defines the first distance between objects depending on the direction [in %]. The default value is 100. Valid values range from 0.01 to 100.
Alpha Mix - Defines the upper limit of how much alpha is added to each object [in %] . Alpha Mix will be visible when using additional Layers. The default value is 100. Valid values range from 0 to 100.
Tone Range - Defines the range of tones analyzed and used by setting a minimum and a maximum value. Narrow the range if your audio signal does not include a wide range of tones to avoid a lot of empty space where no objects are shown. The default values are C1 and C9. Valid values range from C-1 to G9.
Vertical Mode - Activates or deactivates the use of vertical objects. All 3 modes can be used at the same time.
Horizontal Mode - Activates or deactivates the use of horizontal objects. All 3 modes can be used at the same time.
Depth Mode - Activates or deactivates the use of objects in the depth. All 3 modes can be used at the same time.
Mode - Allows you to choose which musical parameter is used [Tone, Interval, Base Type].
MADRIX 5.8.
