DVI |
Overview MADRIX can output DVI.
Usage The DVI window is particularly useful when using a video beamer (VGA or DVI, for example), a DVI wall, the software LED Studio, on-screen capturing, or in similar fields of application.
Activating DVI Output DVI output is only available with MADRIX dvi start, MADRIX dvi, MADRIX professional, and MADRIX ultimate. Any other version, including the demo, will render a rotating cross over the actual output. Only after purchasing MADRIX dvi start, MADRIX dvi, MADRIX professional, or MADRIX ultimate, and the MADRIX KEY (software protection dongle) that comes with it, the cross will disappear.
To activate DVI output, navigate to the menu "Previews" -> "Preview DVI" and then click on "DVI", "Window", or "Fullscreen". Click DVI if you want a borderless DVI window, which is the most important one. You may activate two separate DVI windows (Preview DVI 1 and Preview DVI 2).
Further Configuration Please remember to configure your light matrix in the Matrix Generator or Patch. Please make sure to save your MADRIX Setup after the configuration process.
