DVI Window (With Frame) |
A DVI window with a frame will appear if you have activated this option via the menu "Previews" -> "Preview DVI" -> "Window". You can easily move this window around by clicking and holding the title bar with the left mouse button. In this way, you can also simply drag & drop a DVI window to change its position. Drag the borders of this window in order to resize it.
Settings - Context Menu Overview The context menu makes various options and settings available to the user. To open the context menu, perform a right mouse-click inside the DVI window. In addition, you can navigate to the menu "Previews" -> "Preview DVI", where the same context menu appears.
DVI Map Mode Activate "DVI Map Mode" if you configured an individual DVI Patch including DVI Maps. Grid You can activate and deactivate a "Grid" by choosing this option inside the context menu. Stretch Pixels The function "Stretch Pixels" activates scaling of your preview to the maximum size of your preview window. Show Status Information "Show Status Information" can be used to display some extra information regarding this preview window, such as the size of the matrix or the frame rate. Show Clock "Show Clock" inserts the time into the window. DVI Window Settings "DVI Window Settings" calls up a new dialog.
"Window Position", "Display Rotation", and "Window Size" only apply to the borderless DVI window. "Display Area" specifies what is shown in the DVI window. Activate "Full Size" and your full matrix will be displayed. Or you can select a certain cut-out and specify which details of your matrix will be shown. You can choose the start coordinates and the end coordinates of this area. "Left:" and "Top:" define the start coordinates in a coordinate system that starts with 0,0 in the top left corner. "Right:" and "Bottom:" define the end coordinates. The end coordinates cannot be higher than the full size of the matrix. For example, for a matrix with 50x50 pixels, the maximum value of "Right:" and "Bottom:" is 50. Lock Position You can lock this window at a particular position. Right-click and choose "Lock Position" from the context menu. Always On Top If you want the window to be in the front of all windows at all times, activate the entry "Always On Top". Use Background Image... Allows you to use a picture in "Window" and "Fullscreen" mode instead of the grey background. DVI, Window, Fullscreen "DVI" activates the borderless DVI Window. "Window" activates the framed DVI window. "Fullscreen" activates DVI output in fullscreen mode. Flip Vertically & Flip Horizontally "Flip Vertically" and "Flip Horizontally" will flip the output accordingly. It turns over the image. Close Click "Close" to close this Window.
Further Configuration Further settings can be accessed in the MADRIX Options -> Performance. |
