Menu
Menu
Left Menu
Pinned
[Click To Unpin Again]
Unpinned
[Click To Pin Again]
Pin / Unpin - Allows you to decide if the left menu should always be visible [i.e. pinned] or not [i.e. unpinned].
▪By default, the menu is pinned.
▪By default, menu item Dashboard is selected.
Online Update Available
Shows that your web browser found an active internet connection and automatically checked if a new update is available for your device.
Click on it to directly jump to menu »Update
Top Menu
Disconnected
Shows the Device Name (Long) of the controller and its serial number in combination with the current connection status:
▪Connected
▪Disconnected
If you experience a disconnect, for example in case the network cable got detached, the web panel should automatically reconnect to the controller again if the connection has been established again [in around 30 seconds]. Or you can simply reload the page in the web browser [Usually keyboard shortcut Ctrl + R or F5].
Autosave
If activated, shows the current status of the feature for automatic saving:
▪Autosave Successful!
▪Auto. Saving...
▪Unsaved Changes!
Manual Save
If automatic saving is disabled, manual saving becomes available.
▪Manual Saving Available
▪Man. Saving...
▪Save Successful!
▪Unsaved Changes
▪Preparing To Save
▪Discard Changes
Notifications
Shows the latest errors.
For more information, go to menu »Log
Language Selection
The web panel is available in various languages. Choose from:
▪Deutsch - Activates the German language for the web panel.
▪English - Activates the English language for the web panel.
▪简体中文 - Activates the Simplified Chinese language for the web panel.
▪Español - Activates the Spanish language for the web panel.
▪Français - Activates the French language for the web panel.
▪हिन्दी  - Activates the Hindi language for the web panel.
▪Bahasa Indonesia - Activates the Indonesian language for the web panel.
▪Italiano - Activates the Italian language for the web panel.
▪日本語 - Activates the Japanese language for the web panel.
▪한국어 - Activates the Korean language for the web panel.
▪Português brasileiro - Activates the Brazilian Portuguese language for the web panel.
▪Русский - Activates the Russian language for the web panel.
▪Türkçe - Activates the Turkish language for the web panel.
The default setting is automatically set by using the language locale set for your operating system and web browser.
Once set or once changed, the setting is then saved in the local storage of your web browser [via Cookie].
Profile
By default, no active profile is set up for the controller.
▪That means Web Panel Access Control is disabled.
▪Autosave - As a shortcut, allows you to enable or disable the autosaving feature here.
If you are restricting access to the web panel by enabling Web Panel Access Control and by setting a Username and Password, a profile is created accordingly.
▪See menu »Network to enable or disable Web Panel Access Control.
▪Log Out - Locks access to the web panel again by logging you out.
▪Important: You will automatically be logged out after 30 minutes of inactivity!
Light Theme - Switches the Web Panel from dark colors to mainly light colors.
This is the default setting.
Dark Theme - Switches the Web Panel back from light colors to mainly dark colors.
