Output [sACN]
You Are Here:  Using MADRIX 5 Software >
Output [sACN]
DMX-OUT Over Ethernet Network [Streaming ACN / sACN]
You can connect the STELLA over Ethernet network to the network card of your computer that runs the MADRIX 5 Software. Data is distributed to the device over network cabling [Ethernet] and sent to the output ports [DMX 1 and DMX 2].
1] Initial Configuration
▪Put MADRIX STELLA into operation; as described above. Learn more »Putting The Device Into Operation
▪Connect MADRIX STELLA to your computer using Ethernet network cabling.
▪It is highly recommended to use Gigabit Ethernet network components [network card, switches, etc.].
▪Set up the corresponding settings in the »Configuration Using A Web Browser
2] Windows Network Settings
▪MADRIX 5 automatically sets up Streaming ACN network settings for you.
[MADRIX 5 supports multicast Streaming ACN. Data is automatically sent to all corresponding sACN devices in the network. Unicast is also supported.]
▪You only need a computer with a network card and a valid IP address.
▪You do not have to change the IP address settings in Windows for Streaming ACN!
▪The IP address range for sACN devices is 239.255.X.X according to the Streaming ACN specifications. MADRIX STELLA automatically works this way.
▪Make sure that your Firewall does not block data of the 239.255.X.X IP address range!
▪Check the settings of the Windows Firewall.
3] Fixture Patching In MADRIX 5
▪Start MADRIX 5.
▪Configure the virtual LED matrix using the Matrix Generator or Patch Editor.
4] Activating Streaming ACN
▪Go to the menu Preferences > Options... > Devices Network
▪Activate ESTA - Streaming ACN
▪Choose your network card from the drop-down list. Make sure to select the correct network adapter that will be used for Streaming ACN!
▪ACN Device Count - Set up how many you are going to use. MADRIX STELLA requires 2 sACN devices per unit.
[This is the total amount of devices. Please set the exact number of devices you are using. If the count is higher, this creates unnecessary network traffic.]
▪Click Apply
Devices (Network)
▪ACN CID - Being a network protocol, Streaming ACN sends a so-called CIDs [Component Identifier].
- Every single ACN device has such a unique ID.
- When using Streaming ACN, your MADRIX 5 Software is one of those devices.
- When you start MADRIX 5 for the first time, this ID will be generated automatically for you. From this point onwards it will be used on your PC.
- With this ID your MADRIX 5 Software can be easily identified in the network. Interfaces can detect this unique ID and can be configured to receive data from this particular device. Please note that the ACN interface must support this feature.
- Do not change the ACN CID, unless you are an experienced user!
▪Click OK to close the window.
5] Activating Devices
Each of the ports need to be activated if that is not already the case.
[Keyboard shortcut: F4]
▪Select your devices and their ports in the list. 2 output universes will be shown.
▪Right Mouse Click on the column State to set from Off to On [indicated by green light]. By default, the devices are already activated.
▪[In the screenshot above, one STELLA is connected. If more devices are connected, please use the different universes of different devices and the device details [i] to identify them in the Device Manager.]
▪Universe - Defines which universe of your MADRIX 5 Patch is sent to this particular device.
- Right Mouse Click on the column Universe in order to enter a different number.
6A] Configuration Of Single Devices
▪Select a device in the list and click
ACN DMX Devices
▪A new window will open.
ACN Configure Device
Set up the following settings for your devices:
▪Source Name - Allows you to set up a specific name for the device. This name is send via network as well. Therefore, interfaces may be able to retrieve this name and can be configured to receive data from this source.
- If you are using the default name MADRIX U:X, the universe will automatically be displayed in the name [represented by X: 1, 2, 3, etc.].
▪ACN Universe - Defines the DMX universe of the device.
- Set up the same universe that is set up in your sACN device, which is MADRIX STELLA.
- According to the Streaming ACN specifications, MADRIX 5 will automatically change the ACN IP Address according to the ACN Universe.
▪ACN Priority - Was implemented for backup solutions. Valid values range from 0 to 200, which is the highest priority.
- For example, you may have set up two MADRIX PCs. One gets a priority of 100. The second PC gets a priority of 50. If the first PC fails and only if it malfunctions, data will be automatically received from PC #2.
- Data will always be received from the device with the highest priority. Please note that the ACN device must support this feature.
▪ACN Protocol - Automatically selects the ANSI 2009 standard.
▪Use Multicast
ACN Multicast IP Address - Displays the IP address of the device as automatically assigned by MADRIX 5 according to the Streaming ACN specifications. The last 2 digits match the assigned DMX universe.
▪Use Unicast
ACN Unicast IP Address - Uses a specific IP address to send data to.
▪Click Apply to confirm your changes.
6B] Configuration Of Multiple Devices
▪You can configure several interfaces at the same time.
▪Follow the steps of 6A, but select multiple devices and click
ACN Configure Multiple Devices
▪Set up the settings as described under 6A].
▪For ACN Universe, you have now additional options for Numbering:
Auto Numbering Off        Click the button and MADRIX 5 will automatically increase the ACN Universe number for all the selected devices [which can be seen in the DMX Devices tab of the Device Manager], starting with the value you have entered.
▪Click Apply and OK to confirm your changes.
7] Frame Time
▪Make sure that your device is still selected under Preferences > Device Manager... > DMX Devices
▪Set up the frame time for your device.
  Please note: If you want to output high frame rates, make sure to set Main Mixing FPS in the Options to the same value in order to render the same frame rate [It is set to 50 FPS by default. Otherwise, frames will be duplicated].
  Please note: If you want to input high frame rates, make sure to set DMX Controller Input FPS in the Options to the same value in order to process the same frame rate [It is set to 50 FPS by default. Otherwise, frames will be duplicated].
8] Optimized Frames Or Full Frames
▪Choose how to send data.
- Right Mouse Click or Left Mouse Double-Click on the column Frames to choose between Optimized and Full
- Per DMX512 standard, MADRIX 5 only sends the number of DMX channels that is configured [optimized frames]. For example, if you are using 312 DMX channels on a DMX universe, only 312 DMX channels will be sent with every single frame on this universe.
- Activate Full Frames if devices should always send full frames on a particular universe, instead of optimized frames. Sending full frames means that always the full 512 DMX channels of a DMX universe will be sent with every frame [even when you are using less than 512 channels on the universe].
- Activating Full Frames is recommended if problems with the data output of your devices occur.
