Output [USB]
You Are Here:  Using MADRIX 5 Software >
Output [USB]
DMX-OUT Via USB
You can connect the STELLA directly over USB to the computer that runs the MADRIX 5 Software. Data is distributed to the MADRIX STELLA via USB and sent to the two ports [DMX 1 and DMX 2].
1] Initial Configuration
▪Put MADRIX STELLA into operation by connecting the LED fixtures and supplying power; as described above. Learn more »Putting The Device Into Operation
▪Connect MADRIX STELLA to your computer via USB.
[Use the provided USB cable.]
▪Make sure to check the power-management options of Windows. Learn more »PC Power Management
2] Fixture Patching In MADRIX 5
▪Start MADRIX 5.
▪Configure the virtual LED matrix using the Matrix Generator or Patch Editor.
3] Enabling Drivers
▪Go to the menu Preferences > Options... > Devices USB
▪Activate MADRIX STELLA
▪Click Apply
▪Close the window with OK
Devices (USB/PCI)
4] Activating Devices
[Keyboard shortcut: F4]
▪Your STELLA devices and their two ports will appear in the list.
▪If your devices are not in the list, click
[In the screenshot below, one STELLA is connected.]
▪By default, all ports are activated [State On].
▪If your device and ports are not activated, do the following:
▪Select the device/port in the list.
▪Right Mouse Click on the column State to set from Off to On [indicated by green light].
▪Right Mouse Click on the column OUT / IN to set to OUT for data output.
5] Configuration Of DMX Output
▪Make sure that your devices are still selected under Preferences > Device Manager... > DMX Devices
▪When using your device as an output device, set up Universe
▪This setting assigns a specific DMX universe [of the Patch] to the device or the port of the device.
▪Make sure to assign the correct universe according to your requirements.
Learn more »Glossary
▪By default, DMX universe 1 is assigned to DMX 1 and DMX universe 2 is assigned to DMX 2.
6] Frame Time
▪Make sure that your device is still selected under Preferences > Device Manager... > DMX Devices
▪Set up the frame time for your device.
  Please note: If you want to output high frame rates, make sure to set Main Mixing FPS in the Options to the same value in order to render the same frame rate [It is set to 50 FPS by default. Otherwise, frames will be duplicated].
  Please note: If you want to input high frame rates, make sure to set DMX Controller Input FPS in the Options to the same value in order to process the same frame rate [It is set to 50 FPS by default. Otherwise, frames will be duplicated].
▪[When using USB, the frame time will be automatically set to the same value for all output ports.]
7] Optimized Frames Or Full Frames
▪Choose how to send data.
- Right Mouse Click or Left Mouse Double-Click on the column Frames to choose between Optimized and Full
- Per DMX512 standard, MADRIX 5 only sends the number of DMX channels that is configured [optimized frames]. For example, if you are using 312 DMX channels on a DMX universe, only 312 DMX channels will be sent with every single frame on this universe.
- Activate Full Frames if devices should always send full frames on a particular universe, instead of optimized frames. Sending full frames means that always the full 512 DMX channels of a DMX universe will be sent with every frame [even when you are using less than 512 channels on the universe].
- Activating Full Frames is recommended if problems with the data output of your devices occur.
▪In addition, you can activate Full Frames for the device and each MADRIX STELLA port separately.
