Input [Art-Net]
You Are Here:  Using MADRIX 5 Software >
Input [Art-Net]
DMX-IN Via Ethernet Network [Art-Net Remote]
You can connect MADRIX STELLA over Ethernet network to the network card of your computer that runs the MADRIX 5 Software. Data is sent to the STELLA via a port and from the STELLA to MADRIX 5 via Ethernet network.
1] Initial Configuration
▪Connect your external DMX controller to the DMX port of MADRIX STELLA.
▪Connect MADRIX STELLA to power.
[Please see safety instructions in the MADRIX STELLA Technical Manual & Quick Start Guide!]
▪Connect MADRIX STELLA to your computer via network cabling.
▪It is highly recommended to use Gigabit Ethernet network components [network card, switches, etc.].
▪Set up the corresponding settings in the »Configuration Using A Web Browser
2] Windows Network Settings
Art-Net is a network-based protocol. MADRIX 5 will use the network card of your computer to send data.
▪It is required to set up the correct network settings in Windows, first.
▪You must use these IP address and Subnet mask settings. Otherwise, Art-Net might not work!
▪The IP addresses of your computer and your MADRIX STELLA devices need to be different.
▪Set up an individual IP address in the following IP address range:
- 2.0.0.1 ... 2.255.255.254 or
- 10.0.0.1 ... 10.255.255.254
▪Set up the corresponding Subnet mask
- 255.0.0.0
[Via factory default settings, MADRIX STELLA devices will have an IP address in the 10.x.x.x network range, such as 10.78.0.86, for example].
[Please note: Your devices and the sender, such as the PC that runs MADRIX 5, need to have the same subnet mask!]
▪Restart MADRIX 5, if you have changed the network settings in Windows while MADRIX 5 was running.
3] Activating Art-Net
▪Go to the menu Preferences > Device Manager... > Art-Net
▪Activate the checkbox Enable [in the upper, right corner].
4] Adding Devices Automatically
MADRIX 5 can automatically add your MADRIX STELLA devices.
▪Click
[MADRIX 5 will automatically search the network for connected MADRIX STELLA devices. Devices that are found will appear in the list. One entry will be created in the list for each STELLA device.]
5] Configuration Of Art-Net Input
▪Select your STELLA device in the list with one of its inputs.
▪Click
▪A new window opens [Art-Net Device Configuration].
▪Universe Port IN
- By default, MADRIX STELLA sends DMX-IN data to universe 256 for Port 1 and to universe 255 for Port 2. You can change these settings in the Web Configuration or MADRIX Device Configuration window if required.
- If you have changed the settings, enter the exact same network universes here!
▪Activate Receive Direct IP Mode and enter the IP Address of your MADRIX STELLA. Confirm with Apply
[E.g., 10.78.2.89]
▪[You can also activate Receive Broadcast Mode. In this mode, MADRIX 5 will receive any DMX data that is sent in the network on this particular Art-Net universe.]
▪Click OK
6] Activating Your Art-Net Input Device
You need to activate the Art-Net input device. It is still deactivated.
[Keyboard shortcut: F4]
▪Select the STELLA device in the list per its port.
[You can activate both input ports at the same time.]
▪Right Mouse Click on the column State to set from Off to On [indicated by green light].
▪IN is automatically activated.
▪If required, change the frame time.
  Please note: If you want to output high frame rates, make sure to set Main Mixing FPS in the Options to the same value in order to render the same frame rate [It is set to 50 FPS by default. Otherwise, frames will be duplicated].
  Please note: If you want to input high frame rates, make sure to set DMX Controller Input FPS in the Options to the same value in order to process the same frame rate [It is set to 50 FPS by default. Otherwise, frames will be duplicated].
7] Activating DMX Input
▪Go to the menu Preferences > Device Manager... > DMX Input
DMX Input Tab
▪Select your preferred DMX Universe in the list.
[By default, DMX universe 1 to 8 are listed. If you wish to increase the number of DMX-IN universes, you can change the setting under menu Preferences > Options... > Performance]
▪Choose your DMX-IN Device in the section Device. Select the Art-Net input device via its IP address.
▪Art-Net input is now activated. MADRIX 5 can already receive DMX data.
▪Now, choose how to use incoming data as explained below.
8] Art-Net Remote
Data
▪At this point, MADRIX 5 is now already receiving any incoming data.
▪You can now use this data, for example for Scripts and Macros.
▪If you want to monitor incoming signals, select your DMX universe/DMX device in the list and click
Mapping
▪Use Mapping, if you want to route incoming DMX signals through MADRIX 5 to your output [DMX-Thru].
▪First, select your device in the list.
▪Activate Mapping
▪This feature maps incoming data to the specified DMX universe and channels.
Mapping
▪Configure the following settings in the section Mapping
- Map Channels From - Defines which incoming channels are used. This is the start channel to specify the range of channels.
- To - Defines which incoming channels are used. This is the end channel to specify the range of channels.
- To Universe - Defines onto which output DMX universe MADRIX 5 should map the specified range of incoming channels.
- Start At Channel - Defines the first DMX channel of the output DMX universe MADRIX 5 should use.
- Use HTP - Activates the Highest Takes Precedence feature. You can map incoming data to a DMX address range that MADRIX 5 already controls. Use HTP and MADRIX 5 will compare incoming values with the DMX data it sends to the DMX output. As a result, MADRIX 5 will only use the highest of both values on a particular channel and send it to the output.
▪Click Apply to confirm.
Remote Control
▪Use Remote Control, if you want to control the MADRIX 5 Software remotely
▪Activate Remote
▪Select one of the built-in protocols in the section Remote Control as explained below
or create your own remote configuration.
Mapping
Open MADRIX MIDI Remote Configuration
Open - Loads a previously saved MADRIX 5 DMX Remote Configuration file [of the file type *.mdrx].
DMX-IN Protocols
Protocols - Choose from a pre-configured protocol [configuration].
MIDI Remote Control Edit
DMX-IN Remote Editor - Allows you to modify a configuration or create a new configuration.
Start Address
Start Address - Defines on which particular DMX channel the protocol should start. The whole protocol will be mapped to this new address area.
DMX Watcher - Opens the DMX Watcher to monitor your DMX output or input.
Trigger
▪Use Trigger, if you want to use incoming signals for the MADRIX 5 TRI Effects.
▪Activate Trigger
Mapping
Port - Defines the port [Port 1 - 8] that is assigned to this DMX-IN Device. MADRIX 5 allows you to send trigger signals from up to 8 different devices [8 ports] and assign a MADRIX 5 TRI Effect the corresponding port.
Value Range - Defines the range of incoming DMX values that can be used as trigger signal.
- The minimum and default value is 1.
- The maximum and default value is 512.
Assign Minimum Value - Automatically assigns the minimum value when using the controller.
- Click Assign and use the control on your controller for the minimum value and the value will be set automatically in the MADRIX 5 Software.
Assign Maximum Value - Automatically assigns the maximum value when using the controller.
- Click Assign and use the control on your controller for the maximum value and the value will be set automatically in the MADRIX 5 Software.
