Files
You Are Here:  Using The Software [Views] >
Files
File Transfer Control [FTC] aims to provide a standard method for the transfer of files.
RDM devices need to support this particular feature!
Make sure to select one or more devices first!
Please note that FTC can be used for extensive maintenance, such as transferring and applying firmware/bootloader files. Such processes are likely to interrupt the operation of the device causing temporary unavailability. It is thus not recommended to use FTC during live operation!
File ID
Represents the different file types/file formats a device supports [as reported by the device].
Description
Shows a more in-depth explanation of the File ID [as reported by the device].
Upload
Allows you to upload files to the device for the reported File ID.
See below for more information.
Shows <Not Supported> if uploading to the device is not supported [as reported by the device].
Download
Allows you to download files from the device for the reported File ID.
Shows <Not Supported> if downloading from the device is not supported [as reported by the device].
Upload
Make sure to upload only files with the correct file type/file format!
Workflow
Step 1]
Double-Click
Perform a double-click with your mouse on a row.
Step 2]
Allows you to enter a complete file path, i.e. directory and file name, if you have that detailed information.
Allows you to choose a file from your system.
A new file dialog opens [Open].
Please navigate to the correct folder that includes the file you wish to upload.
Step 3]
A progress bar shows the progression of the file upload.
Step 4]
Status messages show the current status of the process.
Queued - The process will start soon.
Initializing... - The process has been started.
Committing... - The process is in its final stages, such as applying the new firmware on the device.
Cancelling... - A cancellation has been manually ordered by the user.
Successful - The process has been completed.
Failed - There was a problem and the process has not been completed.
Cancelled - The cancellation has been carried out.
Step 5]
Manufacturers can define certain wait times during the process that the software will adhere to.
You can use the »Log to see how long RADAR needs to wait by searching for entries, such as "ftc", "initial delay time", "inter packet delay", "validation delay", "commit delay".
Multiple Devices
When selecting and uploading to several devices, MADRIX RADAR will ask you how to proceed:
Choose Serial Mode if you are unsure how your devices are connected!
Serial Mode
Is the slower but safer way of performing multiple uploads.
Devices will receive the upload one after the other.
This mode should definitively be used if you are uploading firmware to devices that are connected via daisy chaining. Uploading firmwares often require device to restart, which can result in resets of the connection, new IP addresses, etc. which would abort the process for devices connected further down the line.
Parallel Mode
Is the faster but more risky way of performing multiple uploads.
Devices will receive the upload at the same time.
This mode can be used if you are sure that devices are connected in parallel and no disconnects can happen if a device restarts during the process or similar.
Cancel
Aborts the upload process entirely.
Download
Workflow
Step 1]
Double-Click
Step 2]
A new file dialog opens.
Destination File
Allows you to enter a complete file path, i.e. directory and file name, if you know that detailed information.
Allows you to navigate on your system.
A new file dialog opens [Save As].
Please navigate to the correct folder and enter a file name.
Decryption Key
Some downloads my require you to enter a password before a download is permitted.
Activate this option if you know a password is required.
Allowed characters include 0 to 9, a to f [up to 32 characters].
Step 3]
A progress bar shows the progression of the file download.
Step 4]
Committing... - The process is in its final stages, such as validating the file.
Step 5]
Multiple Devices
When selecting and downloading from several devices, MADRIX RADAR will ask you how to proceed:
Choose Serial Mode if you are unsure how your devices are connected or operating!
Serial Mode
Is the slower but safer way of performing multiple downloads.
Parallel Mode
Can be used if you know that your devices are wired in parallel or if the operating mode or connection status does not change during the process.
Cancel
Aborts the download process entirely.
Context-Menu
Request File List (Get:FtcFilelist)
Sends a manual request to ask devices for their file list.
Cancel File Transfers (Set:FtcCancel)
Sends a manual request to abort any file transfers.
Copy Cell To Clipboard
Copy Rows To Clipboard
Copies the currently selected line or lines [that is, all parameter information] into the clipboard/temporary memory. [Keyboard shortcut: Ctrl + Shift + C]
Export List...
Search
▪Search - Enter any text in order to search all parameters in the list.
- For example: Desc:Int shows all lines that include intensity slots by referencing the column Description, for example.
Customization
File ID
Shows or hides the File ID column.
Description
Shows or hides the Description column.
Upload
Shows or hides the Upload column.
Download
Shows or hides the Download column.
Hide All/Show All
Hides or shows all columns, except for the first column.
Restore Default Visibility
Resets the view to the default settings.
Resize All Columns To Content
MADRIX RADAR User Manual 1.5.
