SCE Cells
<< Click To Display Table Of Contents >> You Are Here: MADRIX Effects > [SCE] Static Color Effects > SCE Cells |
SCE Cells mainly creates organic, cellular visuals.
![]() Default Settings |
![]() Customized Example |
▪Colors - Opens the Color Gradient to specify the colors. The default color is Black [Alpha], White.
▪BPM - Defines the speed [when using a direction/movement]. The default value is 600. Valid values range from 0 to 9999.
▪Count X - Defines the number of objects horizontally. The default value is 5. Valid values range from 1 to 1000.
▪Count Y - Defines the number of objects vertically. The default value is 5. Valid values range from 1 to 1000.
▪Count Z - Defines the number of objects in the depth. The default value is 5. Valid values range from 1 to 1000.
▪Size - Is only available for the rendering modes Blobby and Outlined. Defines the size of objects [in % of the Matrix Size]. The default value is 5. Valid values range from 0 to 100.
▪Outer Glow - Is only available for the rendering modes Blobby and Outlined. Defines the outer shimmer of objects. The default value is 5. Valid values range from 0 to 100.
Cell Distribution - Defines how color values are displayed across the objects and effect [Linear, Ease In Bounce, Ease Out Bounce, Ease In Out Bounce, Ease In Circular, Ease Out Circular, Ease In Out Circular, Ease In Cubic, Ease Out Cubic, Ease In Out Cubic, Ease In Sine, Ease Out Sine, Ease In Out Sine, Ease In Exponential, Ease Out Exponential, Ease In Out Exponential]. The default value is Linear. |
Cell Distribution - Defines how the objects are distributed across the parameter and effect [Uniform, Sine Top, Sine In, Sine Out, Sine InOut, Quadratic, Square Root, Cubic]. The default value is Uniform. |
Rendering Mode - Defines how objects are rendered and thus in which way they are displayed [Blobby, Filled, Organic, Outlined]. The default value is Organic. |
| MADRIX 5.8. |
