SCE Bar Bounce
<< Click To Display Table Of Contents >> You Are Here: MADRIX Effects > [SCE] Static Color Effects > SCE Bar Bounce |
SCE Bar Bounce displays moving bars that bounce of the LED-matrix boundaries.
![]() Default Settings |
![]() Customized Example |
▪Colors - Opens the Color Table to specify the colors. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta.
Color Mode - Defines how colors of the Color Table are applied to objects. Choose from Sequential [Default] [colors of objects are changed in sequence of the Color Table when bouncing off], Permanent [each object retains its color, also throughout bounces], or Separate [all objects get assigned a different color from the Color Table, which then changes when bouncing off].
▪BPM - Defines the speed. The default value is 1500. Valid values range from 0 to 9999.
▪Width - Defines the width of objects [in % of the LED-matrix size]. It is only available for certain Shapes. The default value is 15. Valid values range from 0.01 to 100.
▪Peak Width - Defines the extent of the peak, i.e. highest color value, [in % of the Width]. The default value is 25. Valid values range from 0 to 100.
▪Peak Position - Defines the position of the peak [in %, whereas 0 is the middle of the Width]. The default value is 0. Valid values range from -100 to +100.
▪Cross Width - Is only available for Cross Mode [»Using Directions]. Defines the size of crossed colors [in %]. The default value is 50. Valid values range from 1 to 100.
▪Displacement - Defines the amount of distortion. The default value is 0. Valid values range from 0 to 100.
▪Count - Defines the number of bouncing objects. The default value is 1. Valid values range from 1 to 20.
▪Color Fade - Defines the time frame in which the color is shown completely, without fading from or to the next color.
- The left value defines the fade-in, that is how long colors are faded after bouncing off a boundary.
- The right value defines the fade-out, that is how long colors are faded before bouncing off a boundary.
- The default values are 0 and 100. Valid values range from 0 to 100.
Cross Mode Axes - Is only available for Cross Mode. Allows you to choose to which axis Cross Mode applies [Axes 1 And 2, Axis 1, or Axis 2]. The default setting is Axes 1 And 2. |
Displacement Distribution - Is only available for Displacement. Is applied in dependence of the direction that is chosen. Allows you to choose the area the distortion is applied to [Uniform, Linear Increasing, Linear Decreasing, Triangle]. The default setting is Uniform. |
Displacement Speed - Is only available for Displacement. Allows you to choose to speed in which the distortion affects the visuals. The default setting is 10.0. |
Direction/Mode - Allows you to choose the direction of the movement, including Cross Mode. This includes all directions for 2D and 3D mode. This heavily influences the visual outcome of the effect. The default setting is Right. Learn more »Using Directions |
Look-At Type - Allows you to choose from which side you want to look at the effect. This is mainly relevant for 3D. The default setting is Front. Learn more »Using Directions |
Bounce Mode - Defines the moment when objects bounce off. The default setting is Inside. |
Display Mode - Is only available for 2D and 3D modes/shapes. Defines the boundaries for the effect. The default setting is Clip. |
| MADRIX 5.8. |
