Proprietary DVI Devices [5A / A8 / T9] |
This topic includes: ▪Note
Certain DVI hardware is equipped with proprietary protocols. MADRIX 5 has implemented a range of products that are natively supported because of this. MADRIX 5 currently supports the following DVI device types: ▪Colorlight 5A ▪Colorlight A8 ▪Colorlight T9 ▪EuroLite T9 ▪ColourSmart Link
Before you can use MADRIX 5, please make sure that you have configured your LED fixtures and hardware correctly.
There are several steps required to set up proprietary DVI products in MADRIX 5. This chapter is only part of the process. You need to set up other configurations as well [such as virtual LED matrix, DMX Devices, MADRIX Effects, Audio, etc.].
▪Only use a GIGABIT network card [1 GBit/s or 1000 MBit/s]. 100 MBit/s network cards or lower will not work! ▪It is only recommended to use a wired network connection. Using wireless transmission will not work!
1] Install the correct driver. 2] Activate the DVI device in MADRIX 5. 3] Configure various settings.
1] Installing The WinPcap Driver ▪To use DVI devices with MADRIX 5, you have to install the correct driver first. ▪During the MADRIX 5 installation process, make sure to select the check box WinPcap Driver ▪If you have already installed MADRIX 5 without this component, please re-install MADRIX 5. ▪The WinPcap driver will be installed using a second installer. Confirm this setup wizard to install the driver. ▪Learn more »Installation Process
2] Activating The DVI Device ▪Go to the menu Preferences > Device Manager... > DVI Devices
▪A] Add devices automatically.
▪B] Add devices manually.
1] If the drop-down list at the top of the Device Configuration window does not contain an entry, ▪If you are receiving this error message, please resolve these issues and run the MADRIX 5 installer again to install the required drivers [WinPcap Driver].
2] If everything is installed properly, select the network device that communicates with your DVI fixture in the drop-down list at the top of the Device Configuration window. ▪Do not change any other settings here [such as, Color Master] unless you are an experienced user. ▪Click OK
▪The new DVI device will appear in the list after is has been added automatically or manually.
3] Settings There are different Settings available for further configuration. By default, all settings should be set up correctly already. ▪If you change a setting, always click Apply to confirm the changes. ▪Enable - Activates or deactivates the currently selected DVI device. This is activated by default. It needs to be activated in order to work correctly. ▪Use Full Size - Displays the full Matrix Size on the device. This is activated by default and the recommended setting. Scaling is not available.
▪Set Frame Time - Activate in order to set a different frame time in milliseconds. By default, the DVI device is set to be an Event type with the software's main mixing frame rate [50 FPS by default] .
▪ - Removes the currently selected DVI devices. ▪ - Calls up the configuration window again. ▪ - Makes your device flash and will set all pixels instantly to white for testing purposes.
Remember to configure your light matrix in the »Matrix Generator or »Patch Editor Make sure to save your MADRIX 5 Setup after the configuration process.
If you are encountering problems, please work through the following checklist: ▪Check if all network cables are connected correctly. Please do not use a network hub or switch. ▪Check if your hardware is working without MADRIX 5. ▪Check if you have installed the WinPcap Driver during the installation of MADRIX 5. ▪Check if your light matrix is configured correctly in the Matrix Generator or Patch Editor ▪Go to the menu Preferences > Device Manager... > DVI Devices. Check if you have added a new DVI device. ▪Check if Enable and Use Full Size are activated for your device under Preferences > Device Manager... > DVI Devices ▪Configure your hardware controller again if this seems to be necessary. ▪Always configure only one hardware controller. Do not connect two or more controllers while setting the parameters. ▪When using LED Show T9:
MADRIX 5.6. |
