SCE Starfield
SCE Starfield
SCE Starfield mainly simulates a field of stars streaming towards the viewer from the center. This creates a depth effect.
Effect Options
Learn more »Effect Options
▪Color - Defines the color. The default color is White.
▪BPM - Defines the speed. The default value is 1500. Valid values range from 0 to 9999.
▪Length - Defines the length of objects' trace. The default value is 25. Valid values range from 1 to 1000.
▪Count - Defines the number of displayed objects. The default value is 50. Valid values range from 1 to 1000.
▪Size - Defines the size of objects [in % of the Matrix Size]. The default value is 10. Valid values range from 0.01 to 1000.
▪Border - Is only available for 2D outlined shapes or 3D unfilled shapes. Defines how thick the outer line [border] of objects is. The default value is 25. Valid values range from 1 to 100.
▪Rotation - Defines if the objects rotate around the center [in °]. The default value is 0. Valid values range from -3600 to 3600.
▪Distortion - Defines the distortion towards the center creating the depth effect [in %]. The default value is 75. Valid values range from 1 to 100.
Outer Glow / Inner Glow - Is only available for specific Shapes. Defines the outer shimmer or inner gleam of objects. The default settings are 25. Valid values range from 0.01 to 100.
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default setting is Star.
Shape Rotation Type - Is only available for specific Shapes. Defines the angle in which objects are rotated [0°, 90°, 180°, 270°, Random].
Path Alignment - Lets shapes rotate along the path instead of the general direction.
Rendering Mode - Defines how objects are rendered. Each mode may enable additional settings [such as additional Shapes]. Choose from 2 different modes. The default setting is Extended.
Simple - Prioritizes processing speed over rendering possibilities.
Extended - Prioritizes rendering possibilities over over processing speed. This mode may require more performance.
Invert - Inverts the direction of the effect [from outwards to inwards/from near to far].
MADRIX 5.8.
