SCE Noise
<< Click To Display Table Of Contents >> You Are Here: MADRIX Effects > [SCE] Static Color Effects > SCE Noise |
SCE Noise displays by default objects with different shades to create an effect that is often referred to as visual noise.
![]() Default Settings |
![]() Customized Example |
▪BPM - Defines the speed [when using a direction/movement]. The default value is 1500. Valid values range from 0 to 9999.
▪Frequency - Defines the rate at which new visuals are created [in Hz]. The default value is 25. Valid values range from 0 to 50.
▪Size - Defines the size of objects [Width, Height, Depth] [in % of the Matrix Size]. The default values are 1, 1, 1. Valid values range from 0.01 to 1000.
▪Pitch - Defines the distance between objects for all 3 axes [in % of the Matrix Size]. The default values are 1, 1, 1. Valid values range from 0.01 to 100.
▪Border - Is only available for 2D outlined shapes or 3D unfilled shapes. Defines how thick the outer line [border] of objects is. The default value is 0.01. Valid values range from 0.01 to 100.
▪Variance - Refers to the colors that are specified in the Color Table. Defines the minimum and maximum color variability of colors and objects, i.e. shades [in %]. The default values are 0 and 100. Valid values range from 0 to 100.
▪Alpha Mix - Defines the upper limit of how much alpha is added to each object [in %]. Alpha Mix will be visible when using additional Layers. The default value is 100. Valid values range from 0 to 100.
Recolor - Is only available when setting up at least 2 colors in the Color Table. Assigns a new color to an object every time the effect is generated anew; either automatically via the Frequency or manually via Generate. |
Reshape - Is only available when using the Shape Random or Shape Rotation Type Random in combination with asymmetrical shapes. Assigns a new, random Shape to objects every time the effect is generated anew; either automatically via the Frequency or manually via Generate. |
Resize - Is only available when setting up a Minimum Size that is lower than 100 [0 to 99]. Assigns a new, random Size to objects every time the effect is generated anew; either automatically via the Frequency or manually via Generate. |
Generate - Creates the effect anew to produce different visuals. [This is mainly useful when setting a Frequency of 0.] |
Minimum Size - Refers to Size. Defines the minimum size of objects [in %]. The default setting is 100. Valid values range from 1 to 100. |
Outer Glow / Inner Glow - Is only available for specific Shapes. Defines the outer shimmer or inner gleam of objects. The default settings are 0.00. Valid values range from 0.01 to 100. |
Direction - Allows you to choose the direction. This includes all directions for 2D and 3D mode. The default setting is None. Learn more »Using Directions |
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default setting is Rectangle Filled. |
Shape Alignment - Allows you to choose to which side objects are aligned to. This is mainly relevant for 3D. The default setting is Front. |
Shape Rotation Type - Is only available for specific Shapes. Defines the angle in which objects are rotated [0°, 90°, 180°, 270°, Random]. |
Rendering Mode - Defines how objects are rendered. Each mode may enable additional settings [such as additional Shapes]. Choose from 2 different modes. The default setting is Simple. |
Fade - Activates or deactivates fading between colors. |
| MADRIX 5.7. |
