SCE Bounce |
SCE Bounce displays flying objects that bounce off of the outer boundaries or each other.
This MADRIX Effect uses the following, individual controls: ▪Colors - Opens the Color Table to specify the colors. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta. ▪BPM - Defines the speed. The default value is 1500. Valid values range from 0 to 9999. ▪Count - Defines the number of bouncing objects. The default value is 1. Valid values range from 1 to 100. ▪Points - Defines the number of edges [points] an object is made of. The default value is 3. Valid values range from 1 to 20. ▪Width - Defines the width of objects [in %]. It is only available for certain Shapes. The default value is 10. Valid values range from 0.01 to 100. ▪Height - Defines the width of objects [in %]. It is only available for certain Shapes. The default value is 10. Valid values range from 0.01 to 100. ▪Depth - Defines the depth of objects [in %]. This is mainly relevant for 3D. It is only available for certain Shapes. The default value is 10. Valid values range from 0.01 to 100. ▪Border - Is only available for 2D outlined shapes or 3D unfilled shapes. Defines how thick the outer line [border] of objects is. The default value is 1. Valid values range from 0.01 to 100. ▪Fade Out - Adds a visual tail to objects and fades them out slowly. The default value is 0. Valid values range from 0 to 1000.
MADRIX 5.6. |
