SCE Credits
Important Details
SCE Credits shows any text [strings] by flipping through a number of random characters first for show effect.
BPM - Defines the overall speed, i.e. how fast the effect shuffles through characters. The default value is 600. Valid values range from 0 to 9999. [60 BPM represent 1 character per 1 second, while 120 BPM represent 1 character per 2 seconds.]
Strings - Opens the String Table to specify the text.
Learn more »Using Strings [String Table]
Position - Defines the position of the strings in X, Y, and Z [in % of the Matrix Size]. The default values are 50, 50, 50. Valid values range from 0 to 100. [Make sure to set up Vertical Alignment and Horizontal Alignment as well.]
Size - Defines the size of the displayed text [in % of the Matrix Size][Width, Height, Depth]. The default values are 100, 100, 100. Valid values range from 1 to 1000.
Shuffle - Defines the how long a character is shuffled [in % of the time that is needed to fully shuffle and display a single character; until the next character is shown]. The default value is 100. Valid values range from 0 to 1000.
Line Break - Defines the how long it takes until the next lines is started and displayed [in s]. The default value is 1. Valid values range from 0 to 9999.
Page Break - Defines the how long it takes until the next page is started and displayed [in s]. The default value is 1. Valid values range from 0 to 9999.
Page Fade - Defines the how long it takes until the effect fades to the next page [in s] [as a crossfade over black]. The default value is 0. Valid values range from 0 to 9999.
Autostart - If activated, the effect will automatically start when the corresponding Storage Place is selected. It is activated by default.
Start - Force-starts the effect to start again from the beginning.
Font - Opens a new window and allows you to choose a specific font, font size, and other font settings. [Any color set up in this window will be ignored. Use the MADRIX 5 color controls instead.]
Horizontal Alignment - Defines the horizontal alignment of characters [Left, Middle, Right] in relation to the Position. The default setting is Middle.
Vertical Alignment - Defines the vertical alignment of characters [Top, Middle, Bottom] in relation to the Position. The default setting is Middle.
Count - Defines the number of shuffles per letter. Valid values range from 1 to 100. The default value is 10.
Rotation - Allows you to rotate the strings [, 90°, 180°, 270°]. The default setting is 0°.
Last-String Mode - Is only available when Loop Mode of the String Table is disabled. Defines what happens to the text once all characters have been shuffled. The default setting is Stay.
Stay - Leaves the strings on display.
Clear - Makes the strings disappear.
Important Details
Typefaces
Typefaces can be grouped into two main categories:
Serif [Such fonts contain small features at the end of strokes within letters]
Sans-serif [Such fonts have a clearer, simple appearance]
Serif Font
Sans-Serif Font
AaBbCc
AaBbCc
How To Use Other Languages [Such As Russian Or Chinese]
In Windows 10, go to Start > Windows System > Control Panel > Language
Set up the language you want to use [Russian, Chinese, etc.].
In MADRIX 5, select SCE Credits
Click Aa to open the Font window.
Choose a universal, extensive font, such as Arial
Choose Cyrillic [or Chinese, etc.] under Script
Close the Font window.
Put any strings into the String Table
