DVI Examples |
This topic includes: ▪Example: Screen-Capturing With 1 Monitor ▪Example: Screen-Capturing With 2 Graphic Card Output Ports ▪Example: Using Beamers/Projectors/TVs
This topic presents various scenarios how DVI output can be used.
Example: Screen-Capturing With 1 Monitor ▪You might only have 1 monitor [1 monitor output on the graphics card]. But you need to use MADRIX 5 and the DVI output at the same time. ▪In this case, it is recommended to use the MADRIX 5 interface and the DVI output next to each other on your main monitor. ▪Your main monitor has a certain pixel resolution [e.g., 1920 x 1080]. Learn more »DVI ▪Position MADRIX 5 in the upper, left corner. ▪Go to the menu Previews > External Preview 1 > DVI to activate the DVI output. ▪Go to the menu Previews > External Preview 1 > Preview Settings... ▪Set up Left and Top under DVI Window Position [e.g., 1300 and 0] . ▪Activate Previews > External Preview 1 > Lock Position ▪Keep Always On Top is automatically applied/activated.
Example: Screen-Capturing With 2 Graphic Card Output Ports ▪When using screen-capturing, it is usually recommended to use a graphics card with 2 monitor outputs. ▪In this case, you can use the complete monitor 1 for the MADRIX 5 user interface. The DVI output is simply positioned on the monitor output 2. ▪Your main monitor has a certain pixel resolution [e.g., 1920 x 1080]. Learn more »DVI ▪Position MADRIX 5 on your main monitor. Use the normal window size, maximize the window, or use Full Screen mode for MADRIX 5. ▪Go to the menu Previews > External Preview 1 > DVI to activate the DVI output. ▪Go to the menu Previews > External Preview 1 > Preview Settings... ▪Set up Left and Top under DVI Window Position. Make sure to use values that are outside of Monitor 1; Monitor 1 starts at 0,0 instead of 1,1 [e.g., 1920 and 0]. ▪Activate Previews > External Preview 1 > Lock Position ▪Keep Always On Top is automatically applied/activated.
Example: Using Beamers/Projectors/TVs ▪You might want to bring MADRIX Effects to external equipment, such as projectors, beamers, or large TVs. ▪Often, the Full Screen DVI output is needed in this case. ▪Also, projectors, beamers, and TVs often require a high pixel resolution. ▪Position MADRIX 5 on your main monitor. Use the normal window size, maximize the window, or use Full Screen mode for MADRIX 5. ▪Go to the menu Previews > External Preview 1 > Full Screen to activate the DVI output. ▪Click on the DVI output with your mouse to focus it. Now, perform a Right Mouse Click > Move To Next Screen ▪Activate Previews > External Preview 1 > Keep Always On Top ▪If required, activate Previews > External Preview 1 > Stretch Pixels ▪Activate other options as required. Learn more »DVI
MADRIX 5.6. |
