Installation Process
You Are Here:  Getting Started >
Important Information
Please note regarding Purchased Products, Demo Mode, and Updates:
- The MADRIX 5 Software can be downloaded from »www.madrix.com. Regular updates of the software are also available online. If no MADRIX KEY is connected, the software will run in demo mode.
- Learn more »MADRIX KEY [Software License]
It is highly recommended to always use the latest software update.
Using The MADRIX USB Flash Drive
When using a MADRIX USB flash drive for the installation process, please connect the drive to a free USB port of your operational computer. The MADRIX 5 setup will start automatically using an Auto Installer. Please wait until the setup has fully loaded. Then, proceed with the Setup Process as described below. When the Auto Installer does not launch, please navigate to the drive in the Windows operating system and manually start the setup process by performing a double-click on MADRIX_64Bit_Install.exe
Downloading The Software Online
Download MADRIX_Full_Install.exe from »www.madrix.com
After downloading the installer, please double-click with your mouse on this file in order to start the setup process.
Please wait while the Auto Installer is loading the setup.
Afterwards, proceed with the Setup Process as described below.
Setup Process
Please make sure to:
1] Log into the Windows operating system as administrator [Admin].
2] Let the computer process the setup. This may take some minutes depending on the speed of your computer.
3] Allow the Windows operating system to install all drivers. The Windows operating system may ask for your permission to install drivers and expects your confirmation. Please search for such pop-up windows; they might have opened in the background and might be covered by other windows.
4] Connect your MADRIX KEY before you start a software update [not during the first installation]. In this way, the MADRIX KEY firmware can automatically be updated if required.
Please install the MADRIX 5 Software before you connect a MADRIX KEY or a MADRIX hardware interface.
Step 1]
Select your preferred language.
And confirm with OK
You can always quit the setup by clicking Cancel
MADRIX Setup
Step 2]
Click Next to start the installation.
Click Back in order to return to a previous step during the setup process.
MADRIX Setup
Step 3]
The License Agreement will appear. It outlines the terms you are agreeing to by installing the software. You must accept these terms in order to continue.
Please click I Agree
MADRIX Setup
Step 4]
This window allows you to select which components and which drivers you want to install. A description is given for each item.
MADRIX 5 - Is a required component. It refers to the MADRIX 5 Software and all additional software tools.
Desktop Shortcut - Select if you wish to create a shortcut to the MADRIX 5 Software on your Windows operating system's desktop.
Quick Launch Shortcut - Select if you wish to create a shortcut to the MADRIX 5 Software in your Windows Taskbar.
MADRIX KEY Driver - Is a required component. Installs the MADRIX KEY driver. The USB software protection dongle activates the license [MADRIX 5 KEY preprogrammer/ start/ entry/ basic/ professional/ ultimate/ maximum].
MADRIX KEY Firmware Update - Installs the latest firmware on connected USB protection dongles.
- Please disconnect any unwanted dongles or deselect the option! You can always update your MADRIX KEYs later.
- The installer will attempt to check online if a newer firmware version is available and use it accordingly for the update.
- If the online check fails, the update will be done offline using the minimum or current firmware version provided by the installer.
Interface Drivers - Is a required component. Copies the drivers for MADRIX hardware interfaces to the installation directory and installs them for USB ONE, PLEXUS, NEO, LUNA 4/8/16, NEBULA, STELLA, ORION, USB SMPTE.
WinPcap Driver - Select if you wish to use the DVI device types Colorlight 5A, Colorlight A8, Colorlight T9, EuroLite T9, or ColourSmart Link.
Examples - Select if you wish to install examples including setups, effects, scripts, etc. Learn more »Examples
Next - Click Next after choosing the components in order to continue.
MADRIX Setup
Step 5]
Choose an installation directory on your harddisk where the software will be installed. A default Destination Folder will automatically be provided by the setup.
Browse... - Click to change the folder.
Install - Click to start the installation process.
MADRIX Setup
Step 6]
The installation process may take a few minutes.
Installation Complete - Click Next when this message shown.
MADRIX Setup
Step 7]
Run MADRIX 5 - Deselect if you do not wish to start the software now.
Finish - Click to quit the setup.
When starting MADRIX 5 for the first time, please make sure to learn more about working with the Windows operating system.
Uninstallation
Step 1]
Please select your preferred language and confirm with OK
You can always quit the uninstaller by choosing Cancel
Click Back in order to return to a previous step during the process.
MADRIX Uninstall
Step 1]
Click Next to start the uninstallation.
MADRIX Uninstall
Step 2]
This window allows you to select which components and which drivers you want to uninstall. A description is given for each item.
MADRIX 5 - Is a required component. It refers to the MADRIX 5 Software.
Log Files - Select if you wish to remove all files saved for logging. By default, the component is selected.
Documents - Select if you wish to remove the Documents folder specific to this software from the My Documents directory; except log files. By default, the component is not selected.
MADRIX KEY Driver - Select if you wish to uninstall the drivers of the MADRIX KEY. By default, the component is not selected.
[Only remove it if no other software, such as MADRIX RADAR, requires the driver. If you have such software installed and are using it, do not remove the driver.]
Interface Drivers - Select if you wish to uninstall the drivers of the MADRIX hardware interfaces. By default, the component is not selected.
WinPcap Driver - Select if you wish to uninstall the WinPcap driver. By default, the component is not selected.
[Only remove it if no other software requires the drivers. If you have such software installed and are using it, do not remove the driver.]
Uninstall - Click Uninstall after choosing the components in order to continue.
MADRIX Uninstall
Step 3]
The uninstallation process may take a short while.
Uninstallation Complete - Click Close when this message shown.
Software Update
Checking For New Software Versions
It is always recommended to run the latest software version. MADRIX 5 can search for new software updates.
Select the menu Help > Check For Software Updates...
Or you can let MADRIX 5 automatically search for updates.
To do so, select the menu Preferences > Options... > Startup > Check For Software Updates
Choose Skip Update if you would like to skip a particular version.
View Release Notes - Is a link that will open your default web browser and launch the MADRIX website to show all changes and improvements of MADRIX 5 Software updates.
Download - Is a direct link to quickly download the latest MADRIX 5 Software version.
MADRIX Update Dialog
Installing New Software Versions
When a new software version has been released, please update your current MADRIX 5 installation to the newest version.
Check and download the latest MADRIX 5 Software directly as described above.
You can also directly download it from »www.madrix.com
It is not required to deinstall MADRIX 5 before you install a new software version.
The installer will ask you if you would like to update your current MADRIX 5 Software installation. Confirm with Yes
MADRIX 5.8.
