2D Or 3D [X, Y, Z] |
This topic includes: ▪3D [X-Axis, Y-Axis, And Z-Axis]
MADRIX 5 is a versatile and powerful software that can control 2D and/or 3D LED installations. You can use MADRIX 5 ▪to map and control pixel by pixel [pixel mapping, 2D]. ▪to map and control volumetric pixels, i.e. voxels [voxel mapping, 3D]. ▪to combine both options.
Virtual LED Matrix You automatically choose to work with a 2D or 3D project by configuring the virtual LED matrix in the Matrix Generator or Patch Editor. ▪If Z is 1, then you are automatically working in 2D. ▪If Z higher than 1, then you are automatically working in 3D. Workflow In addition, many other parts of the software can work in 2D mode or in 3D mode. For example: ▪Previews ▪Effects ▪Mapping
▪In 2D, only 2 axes are involved:
3D [X-Axis, Y-Axis, And Z-Axis] ▪In 3D, 3 axes are involved:
MADRIX 5.6. |
