Controls [Left/Right]
Submaster Left/Right
Color Filter Left/Right
Filter [FX] Left/Right
Current Storage Place Left/Right
Speed Master Left/Right
Next to Preview Left and next to Preview Right you will find different controls that affect the outcome of an entire effect pipeline [»Work Areas [Left/Right]]. They are available to you per side, as explained below.
Submaster - Controls the intensity of the entire Effect Pipeline Left or Right.
It will affect the visual outcome on Left or Right, independently of which Storage, Storage Place, or Layer is selected.
Left Mouse Click And Hold - Select the required value by moving the fader with the help of your mouse. Release the mouse button to set up the specific value [The fader will disappear automatically].
A value of 255 means full intensity.
A value of 0 means no intensity and will render the effect completely black.
The tooltip shows the currently set value.
Color Filter - Filters the colors of the entire Effect Pipeline Left or Right.
Left Mouse Click And Hold - Select the color using the Color Picker to activate the Color Filter.
Right Mouse Click - Restores the default color.
White is the default color and means that no filter is active.
The Color Filter works in multiply mode [additive mode].
The Color Filter Left/Right works in the same way as the Main Output Color Filter. Learn more »Crossfader And Main Output
Filters FX - Special filters can be applied to an entire Effect Pipeline Left or Right to quickly change your visuals.
Learn more »Filters [FX]
Current Storage Place - Shows the currently selected Storage Place.
Left Mouse Click - Reveals the currently selected Storage Place by changing Storages and scrolling the user interface to it when necessary.
Learn more »Storage Places [256 x 256]
Speedmaster
Speed Master Left/Right - Allows you to speed up or slow down effects.
Each Speed Master influences the speed of the entire Effect Pipeline Left or Right.
The Speed Masters work as a multiplier of the current speed of an effect [that includes the BPM of a Layer, the Pitch of a Layer, and the Pitch of a Storage Place.]
Example: A Speed Master of 2.0 will double the current speed.
How To Use
Move the fader upwards to increase the speed.
Move the fader downwards to decrease the speed.
The default value is 1.0 [which is normal speed].
A value of 0.0 will stop the effects.
The highest value is +10.
The lowest value is -10.
Negative values will reverse the direction of effects [if possible].
Double-click or right-click on the Speed Master button to reset to the value of 1.0
Pause
Pause Button
Pause - Will halt the effect.
Left Mouse Click And Hold - Pauses the effect as long as you hold the mouse button [temporarily].
Left Mouse Double-Click - Pauses the effects permanently. A single click deactivates the permanent stop again.
