Work Areas [Left/Right]
Hierarchy
Workflow Example
The user interface of MADRIX is arranged in a specific way.
MADRIX GUI Overview
While there seem to be a lot of different areas, the GUI can be divided into 3 main sections:
Left [Effect Pipeline Left]
Middle Section [Main Output]
Right [Effect Pipeline Right]
This screenshot clarifies the layout of the 2 pipelines [Effect Pipeline Left is shown in yellow / Effect Pipeline Right is shown in green] and the middle section:
That means you can work independently on the left side or on the right side of MADRIX. You could compare this workflow with the A/B setup of a DJ.
Hierarchy
Furthermore, you can find a distinct visual and logical hierarchy for each effect pipeline:
MADRIX GUI Overview
Left
Middle Section
Right
Preview
[Preview Left,
including Submaster Left, Color Filter Left, Filter Left, Current Storage Place Left, Speed Master Left]
Logo
Preview Main Output
Preview
[Preview Right,
including Submaster Right, Color Filter Right, Filter Right, Current Storage Place Right, Speed Master Right]
Storages
Storage Places
[Storage banks 1 to 256,
including Storage Places 1 to 256 each]
Crossfader
[Fade Area]
Storages
Storage Places
Layers
[Effect Area Left including Layers]
Cue List
Master And Audio Input Level
Layers
[Effect Area Right including Layers]
Your visuals are customized and set up in Layers.
A Storage Place can contain one or multiple Layers.
To use a variety of effects, you can use many Storage Places to store your visuals.
Storage Places are organized in Storages.
A Preview shows what current Storage Place is selected on the current Storage to preview an effect.
The Crossfader and Master define the final output towards your LEDs.
In the following chapters, the different parts will be explained in more detail:
A Preview provides a live display of the currently used effects and lighting visuals.
Learn more »3 Previews
Different controls allow you to change visuals on demand for a whole pipeline.
Learn more »Controls [Left/Right]
A Storage contains Storage Places to help you organize, manage, and store your effects.
Learn more »Storages
An Effect Area offers all the controls to choose and customize effects.
Workflow Example
Thanks to the features of MADRIX, you can flexibly work in many ways.
A possible live work-flow could look like this, for example:
Select an effect on the left side and put it out onto the LEDs.
Prepare the next effect on the right side.
Switch to the right side [using the Crossfader].
Prepare the next effect on the left side.
Etc.
MADRIX 3.6i
