Why Is Power Management Important?
We strongly recommend to deactivate all power saving options in Microsoft Windows in order to ensure an interruption-free operation of MADRIX.
Microsoft Windows operating systems offer a wide variety of power management options. In most cases, PCs, laptops, notebooks, and netbooks benefit from a longer battery life if a good power management is in use. But certain problems might occur because of computer power savings nevertheless:
▪ | After a while your MADRIX KEY cannot be identified by the software anymore. |
▪ | Your hardware interfaces are suddenly deactivated. |
Usage
Make sure to set up power-saving settings especially if you are using:
▪ | A MADRIX KEY [USB dongle] |
▪ | MIDI controllers [via USB] |
▪ | USB hardware interfaces [such as MADRIX NEO] |
▪ | A notebook/laptop to run MADRIX |
Additionally:
▪ | Make sure to change the USB power settings. |
▪ | Especially for notebooks, we recommend to activate the High performance power plan. |
Activate High Performance
This setting will make sure that your notebook or laptop will have all its potential performance available for MADRIX.
▪ | In Windows, select Start > Control Panel > Power Options, and change the power plan to High performance
[You might need to click on Show additional plans]. |
How To Change USB Power Settings
▪ | In Windows, select Start > Control Panel > Power Options > Change power-saving settings |
▪ | Click Change advanced power settings |
▪ | Especially the USB settings are important. Disable the suspend settings! |
▪ | Change any other settings that might interrupt the operation as required [Choose Change advanced power settings]. |
