SCE Screen Capture
SCE Screen Capture
Configuration
Slices
SCE Screen Capture allows you to use any area of your Windows Desktop / Monitor / Screen and capture its content in order to directly bring it into MADRIX. In this way, you can integrate any other software and their output into MADRIX [such as visualizers, presentations, and more]. Basically anything that you can show on your monitor can also be brought into MADRIX.
Filter - Defines a filter color. The default color is White.
Position - Defines the position of the object in X, Y, and Z [in %]. The default values are 0, 0, 0. Valid values range from -1000 to 1000.
Extrusion - Adds depth to the input; i.e. duplicates the input image [in % of the Matrix Size]. This is mainly relevant for 3D. The default value is 100. Valid values range from 0.01 to 100.
Configuration - Allows you to configure the effect. It is highly recommended to adjust the settings. Learn more Configuration
Slices - Is a way to bring 2D content to 3D LED matrices by slicing the content into different parts and applying each slice to X-levels, Y-levels, or Z-levels as required. Learn more Slices
Direction - Allows you to choose the direction. This includes all directions for 2D and 3D mode. The default value is None.
Rotation - Allows you to rotate the input [, 90°, 180°, 270°]. The default value is 0.
Tile - Allows you to tile and duplicate the input and thereby generating patterns.
Seamless - Activates or deactivates a continuous stream of the input image. MADRIX will automatically display the input image again to create a continuous display.
Stretching / Aspect Ratio - Allows you to choose the aspect ratio of the input. The default value is Matrix.
None - Disables stretching.
Configuration
In order to use this MADRIX Effect, click Configuration first.
A new window opens.
Configure the Screen Capture Configuration as required and as explained below.
Performance
These settings affect the performance of the screen capturing. Screen capturing can require a considerable amount of computer performance!
Aero Off
Turns off the Windows desktop composition system called Aero in Windows 7 [which is used for visual effects of the Windows user interface]. MADRIX will check first if the Aero is enabled.
- It is recommended to turn Aero off. This increases the capture frame rate!
- If you activate Aero Off, it will be turned on again once you close the MADRIX software.
Capture Frame Rate
FPS - Defines the frame rate with which MADRIX captures the content.
R - Restores the default settings. The default value is 50.0 FPS.
Capture Area
These settings define the screen area that is used for the screen capturing.
Preset
Allows you to choose a preset for your capture area:
Custom Size - Defines a custom area as the capture area.
- Is automatically selected if you use a Selection Tool or define a Custom Area.
Monitor - Defines a complete output of one monitor as the capture area. The available selection choices depend on the configuration of monitors in Windows [e.g., if one or more monitors are installed].
Virtual Screen - Defines the complete screen output of Windows as the capture area. This often includes all monitors, for example.
Selection Tool
Allows you to define a Custom Area using one of two tools:
Marquee - Allows you to define a capture area via your mouse and keyboard.
- Click Marquee and an overlay will be shown.
- You can freely move the overlay around in order to position it correctly.
- To do so, use the mouse [left mouse click and hold and drag the overlay window].
- Or use the arrow keys on your keyboard [Left, Right, Up, Down].
- You can freely change the size of this overlay in order to set up the correct size.
- To do so, use the mouse and drag the edges of the overlay.
- Or use the following keyboard shortcuts:
- Shift + Up/Down - Reduces the Height.
- Ctrl + Up/Down - Increases the Height.
- Shift + Left/Right - Reduces the Width.
- Ctrl + Left/Right - Increases the Width.
- The upper left coordinates of the overlay [Left, Top] are always displayed in the upper left corner.
- The lower right coordinates of the overlay [Right, Bottom] are always displayed in the lower right corner.
- The Width and the Height of the overlay are always displayed in the center.
- Escape / Enter / Left Mouse Double-Click - Confirms your selection.
Window - Allows you to quickly choose a specific window to use as capture area.
- Click Window and an overlay will be shown that covers complete windows.
- You can freely choose which window should be used as screen capture area.
- Move the mouse to select the window via the overlay.
- Use Ctrl + left mouse click in order to select specific parts of a window [e.g., to select only a specific area of an application].
Custom Area
Define an individual screen capture area by using the four input fields.
Left and Top - Define the start coordinates in a coordinate system that starts with 0,0 in the top left corner.
Width - Defines the total horizontal size of the screen capture area in X.
Height - Defines the total vertical size of the screen capture area in Y.
Slices
SL - Calls up Slice Settings
Slice Settings - Is a way to bring 2D content to 3D LED matrices by slicing the content into different parts and applying each slice to X-levels, Y-levels, or Z-levels as required. [You will get the most benefit out of this feature when using content that are made up of different parts and are especially created for this area of application.]
Example: Your virtual LED matrix is 10 x 8 x 4. Now, you have prepared a video feed and want to display it not only on the first Z-level or use Extrude, but on all 4 Z-levels. Then, you would let MADRIX create 4 slices.
Slice Type - Defines the 3D orientation of how slices are applied to your LED matrix.
Slice Order - Defines how your source content is processed.
- Left To Right - MADRIX slices the content starting left.
- Right To Left - MADRIX slices the content starting right.
- Top To Bottom - MADRIX slices the content starting top.
- Bottom To Top - MADRIX slices the content starting bottom.
Slice Count - Defines in how many slices the content is divided. A value of 1 means that no slices are created and that the video feed is used as one. [A value of 4, for example, will create 4 slices that each make up 25% of the source content.]
The settings with the highest performance are Z-Slices and Top To Bottom
Confirm with OK, restore the default settings via Defaults, or abort the process using Cancel
Learn more »SCE Image
MADRIX 3.6i
