SCE Capture
Slices
SCE Capture allows you to use any video signal of capture devices in MADRIX for live video feeds, such as installed webcams or TV-cards. Such devices need to provide the required Windows driver.
Several capture devices can be used at the same time. For every single Layer a different capture device or the same capture device can be utilized.
If your device offers the correct drivers and is recognized in Windows as a capture device, MADRIX will also have access to the device.
[In MADRIX 2, SCE Capture was part of SCE Video.]
Filter - Defines a filter color. The default color is White.
Position - Defines the position of the object in X, Y, and Z [in %]. The default values are 0, 0, 0. Valid values range from -1000 to 1000.
Extrusion - Adds depth to the input; i.e. duplicates the input image [in % of the Matrix Size]. This is mainly relevant for 3D. The default value is 100. Valid values range from 0.01 to 100.
Open - Allows you to connect a capture device. A new window opens for you to select your device. First, select the device. Second, click OK.
Activating Deinterlace Mode
Deinterlace Mode - Allows you to choose from several Deinterlace Modes. [Is available when a capture device has been opened and connected.]
Often digital cameras, digital broadcasting, or digital filming is done via interlacing. In order to get 25 frames per seconds, 50 pictures are shot and merged/mixed with one another. You receive 25 odd frames [frame set 1] and 25 even frames [frame set 2] that contain different picture information [alternating pixel lines]. In order to get an undisturbed picture, proper deinterlacing is necessary.
None - Deactivates deinterlacing.
Bob - Uses one set of 25 frames [even or odd] and copies missing information from the pictures provided. Pixel lines are copied to create a full image. Activate Top Field First in order to choose odd frames to be processed.
Bob Linear - This is the recommended deinterlace mode. It uses one set of 25 frames, but builds an average for the missing pixel lines. Activate Top Field First in order to choose odd frames to be processed.
Blend - Renders an average image from frame set 1 and frame set 2.
Discard - Simply dismisses missing information. Thereby, pixel lines are excluded. This results in half of the original resolution for the final image. Activate Top Field First in order to choose odd frames to be processed.
Slices - Is a way to bring 2D content to 3D LED matrices by slicing the content into different parts and applying each slice to X-levels, Y-levels, or Z-levels as required. Learn more Slices
Configuration - Allows you to configure the connected device further if such configuration is provided by the device and its driver. [Is available when a capture device has been opened and connected.]
Direction - Allows you to choose the direction. This includes all directions for 2D and 3D mode. The default value is None.
Rotation - Allows you to rotate the input [, 90°, 180°, 270°]. The default value is 0.
Tile - Allows you to tile and duplicate the input and thereby generating patterns.
Seamless - Activates or deactivates a continuous stream of the input image. MADRIX will automatically display the input image again to create a continuous display.
Stretching / Aspect Ratio - Allows you to choose the aspect ratio of the input. The default value is Matrix.
None - Disables stretching.
Slices
SL - Calls up Slice Settings
Slice Settings - Is a way to bring 2D content to 3D LED matrices by slicing the content into different parts and applying each slice to X-levels, Y-levels, or Z-levels as required. [You will get the most benefit out of this feature when using content that are made up of different parts and are especially created for this area of application.]
Example: Your virtual LED matrix is 10 x 8 x 4. Now, you have prepared a video feed and want to display it not only on the first Z-level or use Extrude, but on all 4 Z-levels. Then, you would let MADRIX create 4 slices.
Slice Type - Defines the 3D orientation of how slices are applied to your LED matrix.
Slice Order - Defines how your source content is processed.
- Left To Right - MADRIX slices the content starting left.
- Right To Left - MADRIX slices the content starting right.
- Top To Bottom - MADRIX slices the content starting top.
- Bottom To Top - MADRIX slices the content starting bottom.
Slice Count - Defines in how many slices the content is divided. A value of 1 means that no slices are created and that the video feed is used as one. [A value of 4, for example, will create 4 slices that each make up 25% of the source content.]
The settings with the highest performance are Z-Slices and Top To Bottom
Confirm with OK, reset to default settings via Default, or abort the process using Cancel
Learn more »SCE Image
