SCE Flames
SCE Flames is one of two fire effects.
[In MADRIX 2, SCE Flames was a mode of SCE Fire.]
Colors - Opens the Color Gradient to specify the colors. The default color is Black, Red, Yellow, White.
BPM - Defines the speed. The default value is 3000. Valid values range from 0 to 9999.
Width - Defines the size of the flames [in %]. The default value is 24. Valid values range from 0 to 100.
Height - Defines the height of the flames [in %]. The default value is 30. Valid values range from 0 to 100.
Depth - Defines the depth of the flames [in %]. This is mainly relevant for 3D. The default value is 24. Valid values range from 0 to 100.
Intensity - Defines the thickness of flames [in %]. The default value is 15. Valid values range from 0 to 100.
Direction - Allows you to choose the direction of the movement. The default Direction is Up. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default Direction is Up. Learn more »Using Directions
MADRIX 3.6h
