SCE Fire
Context Menu
SCE Fire is one of two fire effects.
[In MADRIX 2, SCE Fire was a mode of SCE Fire, together with SCE Flames.]
Color - Defines the color via a Color Gradient and various options.
BPM - Defines the speed. The default value is 1500. Valid values range from 0 to 9999.
Height - Defines the height of the flames [in %]. The default value is 75. Valid values range from 1 to 1000.
Direction - Allows you to choose the direction of the movement. The default Direction is Up. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default Direction is Up. Learn more »Using Directions
Context Menu
A context menu allows you to quickly make changes to the colors.
Right Mouse Click - Click with your right mouse button on the color gradient to call up the context menu.
Open... - Loads a previously saved Color Table file from an external file [of the file type *.mctx].
Save... - Saves the current colors as a Color Table file [of the file type *.mctx].
Copy - Copies the current colors into the clipboard as a duplicate.
Paste - Applies all colors from the clipboard to the currently focused color control [Colors, M2L Colors].
Defaults - Restores all default gradient colors.
MADRIX 3.6h
