SCE Fluid simulates gas or liquids.
Learn more »Layers |
| ▪ | Colors - Opens the Color Table or Color Gradient depending on the Color Mode. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta.
Learn more »Using Colors And Intensity |
| ▪ | BPM - Defines the speed. The default value is 3000. Valid values range from 0 to 9999.
Learn more »Using BPM Control |
| ▪ | Radius - Defines the size of impulses [in %]. The default value is 10. Valid values range from 0 to 100. |
| ▪ | Vorticity - Defines how much impulses can swirl in the gas [in %]. The default value is 12. Valid values range from 0 to 100. |
| ▪ | Duration - Defines how long impulses can move through the gas [in %]. The default value is 64. Valid values range from 0 to 100. |
| ▪ | Density - Defines the thickness of the gas [in %]. The default value is 10. Valid values range from 0 to 100. |
| ▪ | Velocity - Defines how fast impulses can move through the gas [in %]. The default value is 10. Valid values range from 0 to 100. |
| ▪ | Fade - Defines how quickly impulses evaporate [in %]. The default value is 5. Valid values range from 0 to 100. |
| ▪ | Deceleration - Slows down the movement of impulses [in %]. The default value is 0. Valid values range from 0 to 100. |
Direction - Allows you to choose the direction of the movement. The default Direction is Up. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default Direction is Up. Learn more »Using Directions
Color Mode - Allows you to choose the color mode [Color Table or Color Gradient]. The default Color Mode is Color Table.
