SCE Drops
SCE Drops displays [falling] drops.
BPM - Defines the speed. The default value is 1500. Valid values range from 0 to 9999.
Size - Defines the size of objects [Width, Height, Depth]. The default values are 1, 1, 1. Valid values range from 0.1 to 1000.
Length - Defines how long the trace of a drop is [in % of the Matrix Size]. The default value is 10. Valid values range from 0 to 100.
Length Offset - Defines if an offset is added to the trace of a drop [in % of the Matrix Size]. The default value is 0. Valid values range from 0 to 100.
Pitch 1 - Defines the first distance between objects depending on the direction [in % of the Matrix Size]. The default value is 0. Valid values range from 0 to 100.
Pitch 2 - Defines the second distance between objects depending on the direction [in % of the Matrix Size]. The default value is 0. Valid values range from 0 to 100.
Alpha Mix - Defines the upper limit of how much alpha is added to each drop [in %]. Alpha Mix will be visible when using additional Layers. The default value is 100. Valid values range from 0 to 100.
Count - Defines the number of objects displayed at once. The default value is 10. Valid values range from 1 to 100.
Direction - Allows you to choose the direction of the movement. The default Direction is Down. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default Direction is Down. Learn more »Using Directions
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default Shape is Rectangle Filled.
Mode - Allows you to choose the mode in which way objects are generated [Random, Linear, or Ping Pong]. The default Mode is Random.
