SCE Bounce displays flying objects that bounce off of the outer boundaries or each other.
Learn more »Layers |
| ▪ | Colors - Opens the Color Table to specify the colors. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta.
Learn more »Using Colors And Intensity |
| ▪ | BPM - Defines the speed. The default value is 1500. Valid values range from 0 to 9999.
Learn more »Using BPM Control |
| ▪ | Count - Defines the number of bouncing objects. The default value is 1. Valid values range from 1 to 100. |
| ▪ | Points - Defines the number of edges [points] an object is made of. The default value is 3. Valid values range from 1 to 20. |
| ▪ | Width - Defines the width of objects [in %]. It is only available for certain Shapes. The default value is 10. Valid values range from 0.01 to 100. |
| ▪ | Height - Defines the width of objects [in %]. It is only available for certain Shapes. The default value is 10. Valid values range from 0.01 to 100. |
| ▪ | Depth - Defines the depth of objects [in %]. This is mainly relevant for 3D. It is only available for certain Shapes. The default value is 10. Valid values range from 0.01 to 100. |
| ▪ | Border - Is only available for 2D outlined shapes or 3D unfilled shapes. Defines how thick the outer line [border] of objects is. The default value is 1. Valid values range from 0.01 to 100. |
| ▪ | Fade Out - Adds a visual tail to objects and fades them out slowly. The default value is 0. Valid values range from 0 to 1000. |
Linear - A linear distribution is used to increase the size regularly.
Quadratic - The majority of objects will be smaller than the rest.
SQRT - Using a square root function the majority of objects will be larger.
Cubic - Uses a cubic distribution with mixed sizes.
Shape - Allows you to choose a specific shape as bouncing objects. The default Shape is Line.
Shape Rotation Type - Is only available for specific Shapes. Defines the angle in which objects are rotated [0°, 90°, 180°, 270°, Random].
Collision - Is not available for Shape Line or Curve. Activates or deactivates if objects collide and bounce off of each other. The default mode is Off.
