M2L Drops
M2L Drops analyzes the intervals of the music and displays in form of moving drops.
[In MADRIX 2, M2L Drops was named M2L Interval Drops.]
BPM - Defines the speed. The default speed is 1500. Valid values range from 0 to 9999.
Size - Defines the width, height, and depth of the drops. The default values are 1, 1, 1. Valid values range from 0.01 to 1000.
Length - Defines how long the tail of a drop is [in %]. The default value is 10. Valid values range from 0 to 100.
Length Offset - Defines if an offset is added to the tail of a drop. The default value is 0. Valid values range from 0 to 100.
Pitch 1 - Defines the first distance between tubes depending on the direction [in %]. The default value is 0. Valid values range from 0 to 100.
Pitch 2 - Defines the second distance between objects depending on the direction [in %]. The default value is 0. Valid values range from 0 to 100.
Alpha Mix - Defines the upper limit of how much alpha is added to each drop [in %]. Alpha Mix will be visible when using additional Layers. The default value is 100. Valid values range from 0 to 100.
Tone Range - Defines the range of tones analyzed and used by setting a minimum and a maximum value. Narrow the range if your audio signal does not include a wide range of tones to avoid a lot of empty space where no objects are shown. The default values are C1 and C9. Valid values range from C-1 to G9.
Direction - Allows you to choose the direction. This includes all directions for 2D and 3D mode. The default value is Down. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default Direction is Down. Learn more »Using Directions
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default Shape is Rectangle Filled.
Mode - Allows you to choose which musical parameter is used [Tone, Interval, Base Type].
