M2L Note Flash
M2L Note Flash analyzes the music for certain notes and flashes the LED matrix when such notes occur in the music.
Fade Out / In - Defines how fast MADRIX flashes [in %]. You can specify the fade-in speed as well as the fade-out speed. The default values are 120 and 3000. Valid values range from 1 to 300.
Sensitivity - Defines how quickly and accurately MADRIX reacts when such notes occur [in %]. The default value is 50. Valid values range from 1 to 100.
Defines the lower limit of the analyzed frequency spectrum. If a note in this range occurs, MADRIX will flash the matrix.
Defines the upper limit of the analyzed frequency spectrum. If a note in this range occurs, MADRIX will flash the matrix.
MADRIX 3.6i
