M2L Color Scroll
▪Introduction
▪Overview
▪Layer Settings
▪Effect Settings
M2L Color Scroll displays moving colors based on the incoming audio.
▪Base Color - Defines the background color of the effect. If no audio input or music is available, this color is shown. The default color is Black.
▪BPM - Defines the speed. The default value is 600. Valid values range from 0 to 9999.
▪Step Width - Defines the number of pixels the effect should scroll in the direction per frame [in %]. The default value is 0.01. Valid values range from 0.01 to 100.
▪Color Width - Defines the minimum width of a single color [in %]. The default value is 10. Valid values range from 0.01 to 100.
▪Cross Width - Is only available for Cross Mode [»Using Directions]. Defines the size of crossing colors [in %]. The default value is 50. Valid values range from 0.01 to 100.
▪Sensitivity - Defines how accurately MADRIX reacts when notes occur [in %] or if notes are filtered out. The default value is 80. Valid values range from 0 to 100.
▪Displacement - Defines the amount of distortion. The default value is 0. Valid values range from 0 to 100.
Cross Mode Axes - Is only available for Cross Mode. Allows you to choose to which axis Cross Mode applies [Axes 1 And 2, Axis 1, or Axis 2]. The default mode is Axes 1 And 2.
Displacement Speed - Is only available for Displacement. Allows you to choose to speed in which the distortion affects the visuals. The default value is 10.0.
Direction/Mode - Allows you to choose the direction of the movement, including Cross Mode. This includes all directions for 2D and 3D mode. This heavily influences the visual outcome of the effect. The default Direction is Right. Learn more »Using Directions
