Storage Places, Submaster, And Cue |
The chapter Storage Areas already introduced the controls you can find in Storage Area A and Storage Area B. This chapter focuses on how to work with Storage Places. It will also provide more details regarding Submaster and cue function.
Working With Storage Places Overview MADRIX provides 2 x 60 Storage Places to save your effects. They are located in Storage A and Storage B, which are positioned below the preview windows. The Storage Places are consecutively numbered from 1 to 60.
After setting up your effect, the effect itself and all corresponding settings will be saved automatically in this Storage Place. You will see a green arrow displayed in the lower right corner of a Storage Place if you have chosen and modified an effect. This corner light indicates that this Storage Place is not empty.
Please note that Storage Places on the other hand are saved in MADRIX setup files. Learn more in the chapter File Types.
Context Menu
The same context menu is available in the menu:
Cue Cue will add the currently selected Storage Place to the Cue List. Open Or Save Single Storage Places can be saved. This means that you can save individual effects. They will be stored in the *.mef file format. Likewise, you can load a Storage Place you once stored by choosing "Open". Learn more about files in the chapter File Types. Copy, Cut, And Paste In total, 120 Storage Places are available to you. If you would like to duplicate or rearrange your setup of Storage Places, use these functions. Be also sure to read the section "Drag & Drop" below. Here is an example: Select a Storage Place that contains an effect. Then, press copy, and select another Storage Place. Click paste. Now, your original effect will be copied from the original Storage to the target Storage. Both Storage Places will show the same effect. Clear If you would like to delete an effect and restore the blank Storage Place, choose the option "Clear".
Drag & Drop The options "Copy and Paste" and "Cut and Paste" are also available using drag & drop. Select a Storage Place and while holding the mouse button, drag it to another Storage Place. This performs a "Copy and Paste". Additionally, hold the "Shift" key during this procedure and a "Cut and Paste" will be performed. Both actions do work within one Storage Area or between both Storage Areas. In addition, you can select a *.mef file in Windows and drag it to a Storage Place of your choice in MADRIX. Such a file is created when you save a Storage Place. Learn more about files in the chapter File Types.
Options From The Edit Menu
Clear In the Edit menu you can "Clear all Storages", "Clear all Storages A", and "Clear all Storages B". This actions will clear all settings on selected Storages. This means that all Storage Places will be deleted and restored to their default state. You will have to confirm your selection with "Yes". Copy With the item "Copy Storage Places" you can copy one, multiple, or all Storage Places from A to B or from B to A. You will see the following dialog open, when you select it.
Storage A is shown in the left part and the Storage B in the right part.
In general, you should first select all Storages you want to copy. Navigate to the other list and choose the Storage Places where your selected Storages should be saved. Then, use one of the buttons described below. Please use the "Ctrl" or "Shift" keys for multiple selection. Especially, in the case of copying images and videos it may take a while to copy all Storage Places. The two progress bars at the bottom of the window will show you the progress.
Cue You can add all Storage Places that contain an effect to the Cue List with the item "Cue All Occupied Storage Places" .
Options From The File Menu Similar to saving a single Storage Place, you can save or load an entire Storage Area. If 120 Storage Places are not enough, this might be a good possibility. This options available from the File menu.
To save a Storage Area, go to "Export" -> "Storage" -> "Storage A" or "Storage B". The file will be a MADRIX Storage Setup File (*.mss). To load a Storage Area, go to "Import" -> "Storage" -> "Storage A" or "Storage B".
Submaster And Cue
Upon clicking, the "Sub" button extends to a fader. Please make sure to press and hold the button at the same time. Afterwards, you can easily move the fader with your mouse. A range of 0 to 255 provides a precise adjustment of the intensity. A value of 0 renders the effect completely black.
Using A Storage Place Macro
