File Types
While working with MADRIX, you will come across several types of files. This chapter explains which file type belongs to which function or which part of the software.
List Of File Types
*.ms2
MADRIX Setup File
Your whole show will be saved. It stores relevant data in one single file including but not limited to patch, effects, settings, Cue List, etc. Please note that videos will not be included in this file.
*.mpf
MADRIX Patch File
Stores your patch. »Patch
*.mfl
MADRIX Fixture Library File
Stores the whole Fixture Library. »Fixture Editor
Please note: The madrix.mfl is being overwritten with an updated version every time a new MADRIX update is installed.
*.mfx
MADRIX Fixture
Stores one single fixture. »Fixture Editor
*.mss
MADRIX Storage Setup File
Stores a complete Storage Area including all Storage Places (and effects). »Storage Areas A & B
*.mef
MADRIX Storage Place File
Stores one single Storage Place, and thereby one effect you created. »Storage Places, Submaster, and Cue
*.mdf
MADRIX Device File
Stores all relevant settings for your (connected) devices. »OUTPUT
*.vdf
Visualizer Device File
Stores all relevant settings for a configured visualizer. »WYSIWYG Visualizer
*.mpds
MADRIX PLEXUS Device Settings
Stores all relevant settings for a MADRIX PLEXUS interface. »MADRIX PLEXUS
*.mlds
MADRIX LUNA Device Settings
Stores all relevant settings for a MADRIX LUNA interface. »MADRIX LUNA
*.mmrc
MADRIX MIDI Remote Configuration File
Stores a MIDI remote control configuration (MIDI map) for a MIDI console. »MIDI-IN
*.mdrc
MADRIX DMX Remote Configuration File
Stores a remote control configuration for DMX-IN. »DMX-IN & Art-Net Remote
*.mrec
MADRIX Record File
Stores recorded shows. »Recording
*.dxd
MADRIX DMX Data File
Stores DMX data for the PLEXUS hardware interface. »Recording
*.mpl
MADRIX Cue List File
Stores the Cue List and its entries and settings. »MADRIX Cue List
*.mit
MADRIX Image Table File
Stores an image table for the SCE Bitmap effect. »SCE Bitmap
*.mct
MADRIX Color Table File
Stores a color table for various effects, such as the SCE Bounce. »MADRIX Effects
*.m2l
M2L Color Setup File
Stores a M2L color table for Music2Light effects. »Music2Light Effects (M2L)
*.log
Log File
A log file created with the MADRIX Logfile tool or the MIDI Watcher. »Tools
*.csv
Comma-Separated Values File
A file format that can be used for the MADRIX Cue List. »File Watcher
*.mas
MADRIX Script File
A script for the MAS Script Effect. »MAS Script Effect
*.macs
Encrypted MADRIX Script File
A compiled and encrypted script for the MAS Script Effect. »MAS Script Effect
*.mms
MADRIX Effect Macro File
A macro for an effect, a Storage Place Macro, or a Main Output Macro. »Macros & Scripts
*.mcm
MADRIX Crypted Effect Macro File
A compiled and encrypted macro for an effect, a Storage Place Macro, or a Main Output Macro. »Macros & Scripts
*.rtc
MADRIX KEY File
Required if the MADRIX KEY should be upgraded. »The MADRIX KEY
*.rtu
MADRIX KEY Update File
Required to upgrade the MADRIX KEY eventually. »The MADRIX KEY
Images And Videos
Furthermore, MADRIX supports every image and video type that is supported by your Windows PC. This could be for example:
Images: *.bmp, *.gif, *.jpg, *.jpeg, *.png, *.tif, *.tiff, etc. (»SCE Bitmap)
Videos: *.avi;*.mpg;*.mov;*.wmv;*.asf;*.divx;*.vob;*.flv, etc. (»SCE Video)
If you are encountering problems using such files, please install the required video or image codec on your PC.
Loading A Setup
As described above, a MADRIX Setup stores a lot of information. When loading a setup, you have different choices to make:
Open Options When Loading A Setup
Select "Load Patch" and the pre-defined virtual matrix and Patch settings will be loaded from this Setup. This overwrites your current Patch. If you deselect this option, your current Patch will be used.
Select "Load DMX Device Settings" and all settings regarding DMX devices will be loaded from this Setup. This can overwrite your current settings. Deselect this option if you have configured your own DMX settings.
Select "Load DVI Device Settings" and all settings regarding DVI devices will be loaded from this Setup. This can overwrite your current settings. Deselect this option if you have configured your own DVI devices settings.
Select "Load Audio Settings" and all settings regarding audio will be loaded from this Setup. This can overwrite your current settings. Deselect this option, if you wish to keep your own audio settings.
