Akai Professional APC mini mk2 [MIDI Map]
<< Click To Display Table Of Contents >> You Are Here: Input, Interoperability, And Remote Control > MIDI [IN / OUT] > Akai Professional APC mini mk2 [MIDI Map] |
▪Cue Lists - Cue List Selection
▪Timelines - Cue Segment Selection
▪Timelines - Timeline Selection
Mode |
Active |
Function |
1 |
Deck A |
2 |
Deck B |
3 |
Group Control |
4 |
Cue List |
8 |
Master |
Sub-Mode |
A |
Mode Deck A: Place Mode Deck B: Place Mode Group Control: Group Value Mode Cue List: Cue |
B |
Mode Deck A: Storage Mode Deck B: Storage Mode Group Control: Group Preset |
Crossfader / Cue List Control |
E |
Mode Deck A: Fade To Left Mode Deck B: Fade To Left Mode Group Control: Fade To Left |
F |
Mode Deck A: Fade To Middle Mode Deck B: Fade To Middle Mode Group Control: Fade To Middle Mode Cue List: Cue List Back |
G |
Mode Deck A: Fade To Right Mode Deck B: Fade To Right Mode Group Control: Fade To Right Mode Cue List: Cue List Go |
H |
Mode Deck A: Auto Fade Mode Deck B: Auto Fade Mode Deck Group Control: Auto Fade Mode Cue List: Cue List Play Pause Toggle |
Flash Sub-Mode |
I |
As long as the button is pressed the Sub-Mode will be swapped. |
Fixture Group Value |
F1 |
Value Fixture Group 1 |
F2 |
Value Fixture Group 2 |
F3 |
Value Fixture Group 3 |
F4 |
Value Fixture Group 4 |
F5 |
Value Fixture Group 5 |
F6 |
Value Fixture Group 6 |
F7 |
Value Fixture Group 7 |
F8 |
Value Fixture Group 8 |
Master Value |
F9 |
Value Output Master |
Action Pads |
Activates desired Place, Storage, Group Preset, Cue, sets the stored value for Groups or Main Output Parameters according to the following descriptions: |
Storage Places Deck A
(Mode: 1, Sub-Mode: A)
Button |
Function |
PAD 1 - PAD 64 |
Activate Storage Place at Deck A according to the PAD number. |
B |
Storage Control Deck A |
E |
Fade To Left |
F |
Fade To Middle |
G |
Fade To Right |
H |
Automatic Fade |
PAD Color |
Meaning |
Storage Place is activated. |
Content is saved at the Storage Place but it is not activated. |
No content is saved at the Storage Place and it is not activated. |
Storage Place is blocked. |
Storages Deck A
(Mode: 1, Sub-Mode: B)
Button |
Function |
PAD 1 - PAD 64 |
Activate Storage at Deck A according to the PAD number. |
A |
Storage Place Control Deck A |
E |
Fade To Left |
F |
Fade To Middle |
G |
Fade To Right |
H |
Automatic Fade |
PAD Color |
Meaning |
Storage is activated. |
Storage Places with content are available at the Storage but it is not activated. |
No content is available at the Storage and it is not activated. |
Storage Places Deck B
(Mode: 2, Sub-Mode: A)
Button |
Function |
PAD 1 - PAD 64 |
Activate Storage Place at Deck B according to the PAD number. |
B |
Storage Control Deck B |
E |
Fade To Left |
F |
Fade To Middle |
G |
Fade To Right |
H |
Automatic Fade |
PAD Color |
Meaning |
Storages Deck B
(Mode: 2, Sub-Mode: B)
Button |
Function |
PAD 1 - PAD 64 |
Activate Storage at Deck B according to the PAD number. |
A |
Storage Place Control Deck B |
E |
Fade To Left |
F |
Fade To Middle |
G |
Fade To Right |
H |
Automatic Fade |
PAD Color |
Meaning |
Group Control - Values
(Mode: 3, Sub-Mode: A)
Button |
Function |
PAD 1 - PAD 8 |
Group 1 to Group 8 - Value 255 |
PAD 9 - PAD 16 |
Group 1 to Group 8 - Value 0 |
PAD 17 - PAD 24 |
Group 1 to Group 8 - Flash To Value 255 |
PAD 25 - PAD 40 |
Not in use. |
PAD 41 - PAD 48 |
Group 9 to Group 16 - Value 255 |
PAD 49 - PAD 56 |
Group 9 to Group 16 - Value 0 |
PAD 57 - PAD 64 |
Group 9 to Group 16 - Flash To Value 255 |
B |
Group Control - Presets |
E |
Fade To Left |
F |
Fade To Middle |
G |
Fade To Right |
H |
Automatic Fade |
PAD Color |
Meaning |
Group Value activate. |
Group Value not activate. |
Flash the Group. |
Not in use. |
(Mode: 3, Sub-Mode: B)
Button |
Function |
PAD 1 - PAD 64 |
Activate Group Preset according to the PAD number. |
A |
Group Value |
E |
Fade To Left |
F |
Fade To Middle |
G |
Fade To Right |
H |
Automatic Fade |
PAD Color |
Meaning |
Group Preset saved. |
Empty Group Preset. |
Cue Lists - Cue Selection
(Mode: 4, Sub-Mode: A)
Button |
Function |
PAD 1 - PAD 64 |
Activate Cue according to the PAD number. |
B |
Cue List Selection |
F |
Back |
G |
Go |
H |
Play / Pause Toggle |
PAD Color |
Meaning |
Cue Playing. |
Cue Available. |
Empty |
(Mode: 4, Sub-Mode: B)
Button |
Function |
PAD 1 - PAD 64 |
Activate a Cue List according to the PAD number. |
A |
Cue Selection |
F |
Back |
G |
Go |
H |
PAD Color |
Meaning |
Cue List activated. |
Cue List available. |
Empty |
(Mode: 5, Sub-Mode: A)
Button |
Function |
PAD 1 - PAD 64 |
Activate Cue Segment according to the PAD number. |
B |
Timeline Selection |
G |
Stop |
H |
PAD Color |
Meaning |
Cue Segment playing. |
Cue Segment available. |
Empty |
(Mode: 5, Sub-Mode: B)
Button |
Function |
PAD 1 - PAD 64 |
Activate a Timeline according to the PAD number. |
A |
Cue Segment Selection |
G |
Stop |
H |
PAD Color |
Meaning |
Timeline activated. |
Timeline available. |
Empty |
Master - Main Parameter
(Mode: 8, Sub-Mode: A)
Button |
Function |
Speed Deck A ![]() |
PAD 1 |
Deck A - Speed Up |
PAD 9 |
Deck A - Speed Down |
PAD 17 |
Deck A - Speed = 1.0 |
Speed Deck B ![]() |
PAD 9 |
Deck B - Speed Up |
PAD 16 |
Deck B - Speed Down |
PAD 24 |
Deck B - Speed = 1.0 |
Output Master ![]() |
PAD 33 |
Main Output Freeze |
PAD 41 |
Main Output - Value Up |
PAD 49 |
Main Output - Value Down |
PAD 57 |
Main Output - Blackout |
PAD 42 |
Audio Output - Value Up |
PAD 50 |
Audio Output - Value Down |
PAD 58 |
Audio Output - Mute |
PAD 35 |
Auto Gain Control - On/Off |
PAD 43 |
Audio Input - Value Up |
PAD 51 |
Audio Input Value Down |
PAD 59 |
Audio Input Mute |
Fade Section ![]() |
PAD 47 |
Fade Type - Up |
PAD 55 |
Fade Type - Down |
PAD 63 |
Fade Type - Crossfade |
PAD 48 |
Fade Time - Plus 0.5 Seconds |
PAD 56 |
Fade Time - Minus 0.5 Seconds |
PAD 64 |
Fade Time - 0.0 Seconds |
B |
Color Filter |
E |
Fade To Left |
F |
Fade To Middle |
G |
Fade To Right |
H |
Automatic Fade |
PAD Color |
Meaning |
Default Value, AGC, or Output Freeze is activated. |
Value Up or Down, Default Value. |
AGC, Mute, Blackout, or Output Freeze is available. |
Blackout / Mute is activated. |
Not used. |
Master - Color Filter
(Mode: 8, Sub-Mode: B)
Button |
Function |
Color Filter Mode ![]() |
PAD 1 |
Color Filter Mode - Allow Through |
PAD 9 |
Color Filter Mode - Filter Out |
PAD 17 |
Color Filter Mode - Colorize |
Color Filter Colors ![]() |
PAD 3 |
Filter Color Red - Value 255 |
PAD 11 |
Filter Color Red - Value 127 |
PAD 19 |
Filter Color Red - Value 0 |
PAD 4 |
Filter Color Green - Value 255 |
PAD 12 |
Filter Color Green - Value 127 |
PAD 20 |
Filter Color Green - Value 0 |
PAD 5 |
Filter Color Blue - Value 255 |
PAD 13 |
Filter Color Blue - Value 127 |
PAD 21 |
Filter Color Blue - Value 0 |
PAD 6 |
Filter Color White - Value 255 |
PAD 14 |
Filter Color White - Value 127 |
PAD 22 |
Filter Color White - Value 0 |
Strobe Mode ![]() |
PAD 41 |
Strobe Mode - Output And Strobe Color |
PAD 49 |
Strobe Mode - Output And Black |
PAD 57 |
Strobe Mode - Black And Strobe Color |
Strobe Colors ![]() |
PAD 43 |
Strobe Color Red - Value 255 |
PAD 51 |
Strobe Color Red - Value 127 |
PAD 59 |
Strobe Color Red - Value 0 |
PAD 44 |
Strobe Color Green - Value 255 |
PAD 52 |
Strobe Color Green - Value 127 |
PAD 60 |
Strobe Color Green - Value 0 |
PAD 45 |
Strobe Color Blue - Value 255 |
PAD 53 |
Strobe Color Blue - Value 127 |
PAD 61 |
Strobe Color Blue - Value 0 |
PAD 46 |
Strobe Color White - Value 255 |
PAD 54 |
Strobe Color White - Value 127 |
PAD 62 |
Strobe Color White - Value 0 |
Strobe ![]() |
PAD 48 |
Strobe Speed - Up |
PAD 56 |
Strobe Speed - Down |
PAD 64 |
Strobe |
A |
Main Parameter |
E |
Fade To Left |
F |
Fade To Middle |
G |
Fade To Right |
H |
Automatic Fade |
PAD Color |
Meaning |
Activated. |
Value available. |
Not used. |
| MADRIX 5.8. |
