Art-Net (Output) |
Introduction The Art-Net protocol is a widely known standard to transfer DMX512 over Ethernet (network).
Usage This chapter describes how Art-Net can be used to connect your MADRIX PC to the MADRIX PLEXUS via network cables to output DMX data. DMX data is then sent to the device over Ethernet/network.
Using MADRIX Please make sure to install the MADRIX software first. For more information about the installation process, see the MADRIX PLEXUS Quick Start Guide or the MADRIX Help And Manual.
Connecting MADRIX PLEXUS To Your PC Now, please connect the MADRIX to your computer using the network connection. Your device can be powered via the USB port or by using the external power supply.
Network Settings Please make sure that the network settings of your operating system and the settings of your PLEXUS device are correct! To configure the IP address, subnet mask, and standard gateway of your device, go to the PLEXUS menu 'Network' > 'IP Address'. Or use the PLEXUS Configuration dialog.
In general, these settings are recommended: Device and network card:
Subnet mask:
It is recommended to use this address area. Please note: Recently, the 2.x network range has been made public. That is why MADRIX PLEXUS will have an IP address in the 10.x address range when shipped.
Settings Of The Device Navigate to the menu 'Network' > 'Art-Net'. Art-Net -> DMX 1 shows which Art-Net universe is assigned to the first XLR port for output (DMX 1). Please change the Universe according to your requirements or deactivate the option by choosing Off. Art-Net -> DMX 1 and Art-Net -> DMX 2 specify if incoming Art-Net data is routed to the corresponding XLR port (DMX 1 or DMX 2) and which Art-Net universe should function as source for each port. These settings should be activated if you want to connect your MADRIX PC to your PLEXUS device using network cables. In Live Mode, you would then send data over the network to the PLEXUS and the PLEXUS outputs the data to each XLR port, where your LED fixtures, LED controllers, or LED drivers would be connected. DMX 1 -> Art-Net and DMX 2 -> Art-Net specify if the corresponding XLR port is used for DMX-IN and if those incoming values should be broadcasted to the Art-Net network and to which Art-Net universe it should be sent. You can use this option to control the MADRIX software remotely (Art-Net Remote), for example. You may change the settings in this menu, on the device (How To Edit Values). You can also configure the settings in the PLEXUS Configuration dialog using MADRIX. For more information, see Managing Devices Further. For more information about Art-Net Remote, see the chapter Art-Net Remote (Input).
Configuring Your Virtual Matrix In MADRIX You will need to configure your virtual matrix according to your LED installation. Start the MADRIX software now if not yet done. In MADRIX, navigate to the menu 'Preferences' > 'Matrix Generator' or 'Preferences' > 'Patch' for this task. For more information, please read the MADRIX Help And Manual.
Configuring Art-Net In MADRIX In MADRIX, please navigate to the menu 'Preferences' > 'Device Manager' > tab 'Art-Net'.
Your device will be shown in the list. (The entry 'ArtNetRemote' will be created automatically when activating Art-Net and can be ignored at this stage.) Art-Net is now activated. But you will still need to configure DMX output, as described below.
Configuring DMX Output In MADRIX Activating Your Device In MADRIX, navigate to 'Preferences' > 'Device Manager' (or press 'F4'). Open the first tab 'DMX Devices'. This window shows your connected devices. Two list entries will be created for your PLEXUS device and Art-Net, one entry for each DMX port. At this stage, both ports are deactivated. Please activate the option 'Enable' for both ports, if required!
Setting Up The DMX Universe
Make sure that this configuration match the settings of your virtual matrix in the Patch.
Further Configuration You can also define the 'Frame Time' in ms for each device. Setting up the frame time can help in different cases. For example, certain LED fixtures might work best with a specific frame rate. Make sure to use the optimal frame rate for your fixtures. Some LED fixtures might have problems with high frame rates. Then, you can increase the frame time and the FPS will be adjusted automatically. Always press 'Apply' to activate any changes you made.
Select one ore more interfaces and press the button. The corresponding fixtures connected to the selected interface(s) will completely light up white for a better identification. This makes it easier to see them on stage. It considerably speeds up the procedure of programming the selected DMX512/Art-Net interfaces.
Press 'OK' when you are finished setting up your devices.
Resizing The Window If wish to resize the window of the Device Manager to see more devices in the list, simply move your mouse pointer to the bottom of this window. Then, select the border and hold the left mouse button, while moving your mouse downwards.
Monitoring DMX Output Or DMX Input You can monitor incoming or outgoing DMX values on your device in the PLEXUS menus 'Tools' > 'Monitor DMX 1' and 'Tools' > 'Monitor DMX 2'.
Important Notes Please make sure to save your MADRIX Setup after the configuration process.
You may want to configure further settings for Art-Net.
If you press one of the above buttons, the following window 'Art-Net Device Configuration' will be opened. 'Send Broadcast' will send data to all devices in the network. 'Send Direct' will send data only to a specific address.
Sync Mode
This Sync Mode is not conform to Art-Net. To work properly it needs to be implemented by the manufacturer. Please check the manual of your Art-Net node if this option is available to you. Before activating sync, make sure that all activated Art-Net devices are available in your network! Else, the frame rate of Art-Net might drop. If you are not sure, do not enable any sync mode. Even if your Art-Net hardware does not support Pre Sync or Post Sync mode, it might be advisable to activate it in MADRIX. In this way, data packages will be sent one after another and will not get mixed up. The data will be sent more precisely. But please make sure that all of your interfaces are available in the network.
In MADRIX, navigate to the menu 'Preferences' > 'Device Manager' > 'Art-Net'. Click 'Sync' and a new dialog will open. Now, choose if you want to activate sync packages to be sent before data is sent ('Pre Sync'). Or you can send sync packages after Art-Net data has been sent ('Post Sync'). Then, press 'OK'. If you want to disable sync mode, click 'Sync' again and uncheck the mode that is selected. Then, press 'OK'.
Config By Web
For more information, see Remote Control.
